paintdrying Posted October 20, 2011 Share Posted October 20, 2011 Sorry to ask a question that has been asked so many times but I am having trouble find a simple explanation. I have a 1996 subaru legacy wagon l I believe the 2.2 motor. My question is in the rear of the wagon between the cat and the muffler there is a joint. It is loose and leaking. Can I grind the bolts off and put a new nut and bolt in there. And what do I use between the two surfaces. A donut, a gasket, both? Rtv?There is wiggle in the joint. I live in Vermont so everything is going to be rusty as heck. If it is going to be that hard to seal maybe I should just cut the joint out all together and clamp a soup can in there. Link to comment Share on other sites More sharing options...
Osei Posted October 24, 2011 Share Posted October 24, 2011 New gasket pluas bolts and nuts. There is a spring on each one. Its called a flex joint. See: http://opposedforces.com/parts/legacy/us_b11/ O. Link to comment Share on other sites More sharing options...
