m sprank Posted October 9, 2011 Share Posted October 9, 2011 The FP68HTA is one of the most popular turbos available for the WRX/STi/LGT right now. If you are planning on installing one in a 2007+ LGT there is a small fitment issue that needs to be corrected before install. I will walk you through. On the 2007+ LGT's there is the infamous air pump system. A secondary solonoid and atmospheric pressure sensor reside on the passenger side of the motor under the manifold. It is the first pic. If you install the 68HTA it will hit the electrical connector and not allow installation of the coupler. There are ways to force it, but it causes pic 2, 3 and 4. Crushed electrical connector (and a hole in the coupler too). So, lets walk through how to properly clock a FP68HTA so that it can be installed without hitting the sensor. The FP68HTA from my car. First, remove the wastegate actuator. 1 c-clip and two 10mm bolts. Next remove the band clamp. With the band clamp removed you can separate the two halves of the turbo. They pull apart very easily. http://legacygt.com/forums/attachment.php?attachmentid=84300&stc=1&thumb=1&d=1272925442 http://legacygt.com/forums/attachment.php?attachmentid=84301&stc=1&thumb=1&d=1272925442 http://legacygt.com/forums/attachment.php?attachmentid=84302&stc=1&thumb=1&d=1272925442 http://legacygt.com/forums/attachment.php?attachmentid=84303&stc=1&thumb=1&d=1272925442 http://legacygt.com/forums/attachment.php?attachmentid=84304&stc=1&thumb=1&d=1272925442 http://legacygt.com/forums/attachment.php?attachmentid=84305&stc=1&thumb=1&d=1272925442 http://legacygt.com/forums/attachment.php?attachmentid=84306&stc=1&thumb=1&d=1272925442 http://legacygt.com/forums/attachment.php?attachmentid=84307&stc=1&thumb=1&d=1272925442 http://legacygt.com/forums/attachment.php?attachmentid=84308&stc=1&thumb=1&d=1272925442 http://legacygt.com/forums/attachment.php?attachmentid=84309&stc=1&thumb=1&d=1272925442 Link to comment Share on other sites More sharing options...
m sprank Posted October 9, 2011 Author Share Posted October 9, 2011 Now you can see the retaining in on the outlet side. This in is stopping the outlet side from rotating. You can also see the large snap ring holing the "guts" into the housing. The snap ring is large and you can remove it with standard ring pliers, but heavy duty ones will make the job easier. Either way a second set of hands in useful for removal. With the ring removed we can now separate the "guts" from the housing completely. This exposes the pin on the inlet side that is stopping the inlet side from rotating. Time to get crazy with the dremel. I used a standard heavy duty cutting wheel (part #420) to grind down both pins. Be very careful on the inlet side as the aluminum is soft. http://legacygt.com/forums/attachment.php?attachmentid=84310&stc=1&thumb=1&d=1272925513 http://legacygt.com/forums/attachment.php?attachmentid=84311&stc=1&thumb=1&d=1272925513 http://legacygt.com/forums/attachment.php?attachmentid=84312&stc=1&thumb=1&d=1272925513 http://legacygt.com/forums/attachment.php?attachmentid=84313&stc=1&thumb=1&d=1272925513 http://legacygt.com/forums/attachment.php?attachmentid=84314&stc=1&thumb=1&d=1272925513 http://legacygt.com/forums/attachment.php?attachmentid=84315&stc=1&thumb=1&d=1272925513 http://legacygt.com/forums/attachment.php?attachmentid=84316&stc=1&thumb=1&d=1272925513 http://legacygt.com/forums/attachment.php?attachmentid=84317&stc=1&thumb=1&d=1272925513 http://legacygt.com/forums/attachment.php?attachmentid=84318&stc=1&thumb=1&d=1272925513 http://legacygt.com/forums/attachment.php?attachmentid=84319&stc=1&thumb=1&d=1272925513 Link to comment Share on other sites More sharing options...
m sprank Posted October 9, 2011 Author Share Posted October 9, 2011 You can now see that the retaining pins have been ground down sufficiently to allow both haves of the housing to rotate independently. Time to reinstall the "guts" and snap ring. On this application it is the inlet side we need to rotate. So, I rotate the inlet before re-installing the snap ring. Since the outlet side needs no rotating I mark the edge where the in was with a sharpie. I then mark the opposite edger where the hole is with a sharpie. I line up the two hash marks and re-install the retaining ring. Now all the oil and coolant lines are still at the proper position and my 68HTA is clocked enough to install with good clearance. Make sure not to over clock the turbo as this can cause the wastegate to bind. The turbo clocks further than the wastegate. I hope this helps someone else. http://legacygt.com/forums/attachment.php?attachmentid=84328&stc=1&thumb=1&d=1272925609 http://legacygt.com/forums/attachment.php?attachmentid=84329&stc=1&thumb=1&d=1272925609 http://legacygt.com/forums/attachment.php?attachmentid=84330&stc=1&thumb=1&d=1272925609 http://legacygt.com/forums/attachment.php?attachmentid=84331&stc=1&thumb=1&d=1272925609 http://legacygt.com/forums/attachment.php?attachmentid=84332&stc=1&thumb=1&d=1272925609 http://legacygt.com/forums/attachment.php?attachmentid=84333&stc=1&thumb=1&d=1272925609 http://legacygt.com/forums/attachment.php?attachmentid=84334&stc=1&thumb=1&d=1272925609 http://legacygt.com/forums/attachment.php?attachmentid=84335&stc=1&thumb=1&d=1272925609 Link to comment Share on other sites More sharing options...
m sprank Posted January 1, 2014 Author Share Posted January 1, 2014 http://legacygt.com/forums/attachment.php?attachmentid=171328&d=1388592819 Link to comment Share on other sites More sharing options...
m sprank Posted March 26, 2016 Author Share Posted March 26, 2016 Have a Happy Easter!!! Link to comment Share on other sites More sharing options...
Rester5350 Posted March 27, 2016 Share Posted March 27, 2016 You too Mike ! Link to comment Share on other sites More sharing options...
SBT Posted March 27, 2016 Share Posted March 27, 2016 Always a durable and time-unbound walk-through. Thanks Mike. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
m sprank Posted March 29, 2016 Author Share Posted March 29, 2016 Thanks all. I know the 68HTA is not the "turbo of the week" anymore. But the info still applies to many current turbos. Link to comment Share on other sites More sharing options...
m sprank Posted November 11, 2016 Author Share Posted November 11, 2016 http://www.infamousperformance.net/storage/happy-veterans-day-pictures.jpg The soldier above all others prays for peace, for it is the soldier who must suffer and bear the deepest wounds and scars of war. Douglas MacArthur Link to comment Share on other sites More sharing options...
