_MFB_ Posted August 25, 2014 Share Posted August 25, 2014 This works for SH (09 to 10) , Impreza 08+ , Sti 08+ (manual trans, no need for connectors). Any info on how to do this on subarus with newer instrument panels? Link to comment Share on other sites More sharing options...
m sprank Posted August 26, 2014 Author Share Posted August 26, 2014 Hitachi HDS-5000 aka Subaru Select Monitor II. Link to comment Share on other sites More sharing options...
alex0856 Posted December 26, 2015 Share Posted December 26, 2015 Sorry for epic thread revival but, If there is a CAN (Controller Area Network) bus communication error, you will see only "----" in the display. Basically, that means that the network in your car is broken. That will need to be repaired before anything else can be done. I'm getting this error when trying to read codes...mine's a 5MT and the white plugs are connected. Where should I start? My motor was recently replaced - is it possible something was left unplugged? Link to comment Share on other sites More sharing options...
m sprank Posted December 28, 2015 Author Share Posted December 28, 2015 It is possible something was missed in the wiring. It is also possible something has been damaged. Seeing how the ABS controller is part of the CAN comm and uses the under hood wiring harness (where work was recently done), I would check that first. Link to comment Share on other sites More sharing options...
alex0856 Posted January 2, 2016 Share Posted January 2, 2016 If I can't get this fixed soon, should I be worried? Link to comment Share on other sites More sharing options...
m sprank Posted January 5, 2016 Author Share Posted January 5, 2016 If the car is driving/braking normally it should not be an issue. Safety first. Link to comment Share on other sites More sharing options...
m sprank Posted March 26, 2016 Author Share Posted March 26, 2016 Have a Happy Easter!!! Link to comment Share on other sites More sharing options...
m sprank Posted November 11, 2016 Author Share Posted November 11, 2016 http://www.infamousperformance.net/storage/happy-veterans-day-pictures.jpg The soldier above all others prays for peace, for it is the soldier who must suffer and bear the deepest wounds and scars of war. Douglas MacArthur Link to comment Share on other sites More sharing options...
issjoe Posted September 6, 2018 Share Posted September 6, 2018 How to Read Diagnostic Trouble Codes on 2005 thru 2009 Subaru Legacy and Outback The 2005 thru 2009 model year Legacy and Outback can display Diagnostic Trouble Codes (DTCs) directly on the dashboard. No scan tool is needed. No jumper wires are required, and it is not necessary to count blinking lights. The codes are displayed in plain text on the instrument cluster. Trouble codes from the ECM (Engine Control Module), TCM (Transmission Control Module) and ABSCM/VDCCM (ABS or VDC Control Module) are displayed. This procedure was distilled from the FSM. The English translation in the FSM is not very good, so I have attempted to make it easier to follow. The FSM has this procedure in the Body Section, Instrument/Driver Information, Combination Meter System chapter. Some notes before starting: - I believe this procedure will work for all 2005 to 2009 Legacys and Outbacks. However, I have only tested the procedure on a 2005 Legacy 2.5i 4EAT and a 2008 Legacy GT 5EAT. - I don't know of a way to reset the codes without a scan tool. Disconnecting the battery may or may not work. - Exactly what you will see depends on what type of display your car has. The Procedure Starting condition: key off, headlight switch off. Steps 1 through 7 must be performed within 10 seconds. 1. Turn key to ON position. This is the normal running position, the click just before starting, when all the lights on the dash come on, but before you twist to START. Don't start the engine! 2. Within 3 seconds, turn the headlight switch ON. 3. Press the Trip/Odometer button 4 times. 4. Turn the headlight switch OFF. 5. Press the Trip/Odometer button 4 times. 6. Turn headlight swtich ON. 7. Press Trip/Odometer button 4 times. At this point, the DTC display will begin. 8. Turn headlight switch OFF. Not necessary for the procedure, but your display may be dimmed and hard to read in bright sunlight. Besides, why drain the battery? The DTCs for each module will display in order: ECM, TCM, ABSCM/VDCCM. Press the Trip/Odometer button to cycle between modules. The FSM states that the display will cycle between modules automatically every three seconds if the button is not pushed, but that did not happen in my car - I had to push the button to cycle the display. For each module, there are three display states: - Receiving DTC from module (blinking "P" or "C") - DTC detected & displayed ("P" or "C" followed by 4 digits) - No DTC found ("P" or "C" followed by "----") If there is a CAN (Controller Area Network) bus communication error, you will see only "----" in the display. Basically, that means that the network in your car is broken. That will need to be repaired before anything else can be done. Notes - TCM error codes will not be displayed for cars with manual transmissions. The TCM display state will remain in "Receiving DTC" (blinking "P" on display). In my case, my car is an automatic, but the blinking "P" remained, possibly because I have no codes set. - To cancel the DTC display, turn the key to OFF. - If the engine is started, the DTC display will remain until the car starts to move. (I did not test this) - Past DTCs that have been repaired will be displayed until the engine is started 3 times. (I did not test this) Instructions for Manuals Look up into the fuse box area. Connectors are usually taped up by drivers left leg (to the right once looking inside fuse box). Connect the plugs together. Turn the key to the "on" position. When the gauges are sweeping, press the trip/odometer button on the dash once for DTC display mode and twice for self diagnostic mode. In DTC mode, the error messages and codes are the same as above. Link to comment Share on other sites More sharing options...
