Baddog Posted January 9, 2012 Share Posted January 9, 2012 what kind of rear 22-25 sway bar do you have? ....the tribeca 25 fits a 2nd gen front?? I have the Rallitek rear bar. I also do have the tribeca bar. It mounts on the outside of the endlinks. Was kind of a pain to install only due to bushing fitment. If you have an L I guess the bushing mounts are different. If you have the GT I would get the "Energy Suspension" 25mm bushing kit. $15-20. Link to comment Share on other sites More sharing options...
NickLippert Posted January 9, 2012 Share Posted January 9, 2012 Threw the STi struts on and they were just fine, well after we broke loose the crappy rusty bolts. Link to comment Share on other sites More sharing options...
G Man Posted January 15, 2012 Share Posted January 15, 2012 Will STI Lateral Links and Trailing Arms for a 02-05 WRX fit on a 95 Legacy Sedan. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted January 16, 2012 Share Posted January 16, 2012 I can't help but think that a Tribeca bar would be overkill for these cars. Unless you want a perfectly flat racing car... My 22mm RalliTek bar on the middle setting has eliminated a SIGNIFICANT portion of the body roll on my car... and mine is a high-riding Outback with 150,000 miles on the struts... so I can only imagine that a regular legacy could get pretty close to flat with that bar. Link to comment Share on other sites More sharing options...
JAC Wagon Posted January 17, 2012 Share Posted January 17, 2012 My lowered outback has the rallitek rear sway set on 25 mm... its tight. tight like a tigah Link to comment Share on other sites More sharing options...
jamaha51 Posted January 20, 2012 Share Posted January 20, 2012 Would the this front strut bar work on our legacys? I think the rear works but I keep finding mixed answers on the years for the fronts. http://www.ebay.com/itm/350524765766?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Link to comment Share on other sites More sharing options...
NickLippert Posted January 21, 2012 Share Posted January 21, 2012 Would the this front strut bar work on our legacys? I think the rear works but I keep finding mixed answers on the years for the fronts. http://www.ebay.com/itm/350524765766?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Looks like no, I compared the whiteline part numbers for the BD and GDs. Link to comment Share on other sites More sharing options...
Baddog Posted January 22, 2012 Share Posted January 22, 2012 93-01 Impreza Front 02-07 WRX Rear If I remember right. Link to comment Share on other sites More sharing options...
Baddog Posted January 24, 2012 Share Posted January 24, 2012 Sti control arms. Do they bolt right up? Link to comment Share on other sites More sharing options...
subikid90 Posted January 26, 2012 Share Posted January 26, 2012 Sti control arms. Do they bolt right up? I want to say no because of the wider stance of the sti, but I have never tried them. I think I remember someone on here trying to get them to work and had to buy jdm ones instead but I could be completely wrong. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Baddog Posted January 27, 2012 Share Posted January 27, 2012 did some research.they do bolt up.just need sti endlinks. not the ball joint looking ones. and different front bushings or grind them a little. Link to comment Share on other sites More sharing options...
subikid90 Posted January 28, 2012 Share Posted January 28, 2012 I wonder if it is worth the time and money...lol -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Baddog Posted January 28, 2012 Share Posted January 28, 2012 I hear if you get the USDM 04-06 STI ones its well worth it. It gives around 2 degrees of caster. I am going to give it a try here in the next month or two. Found a bent control arm. So might as well upgrade. Gives it a wider track. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted January 30, 2012 Share Posted January 30, 2012 Are the sway bars on our Legacy's interchangeable with a 97 Impreza OB Sport? A friend might be picking one up soon and we wanted to see if it was possible to upgrade the OBS sways by swapping from a parts car. Link to comment Share on other sites More sharing options...
subikid90 Posted January 31, 2012 Share Posted January 31, 2012 I hear if you get the USDM 04-06 STI ones its well worth it. It gives around 2 degrees of caster. I am going to give it a try here in the next month or two. Found a bent control arm. So might as well upgrade. Gives it a wider track. In for the results! You got me interested now lol -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Baddog Posted January 31, 2012 Share Posted January 31, 2012 Are the sway bars on our Legacy's interchangeable with a 97 Impreza OB Sport? A friend might be picking one up soon and we wanted to see if it was possible to upgrade the OBS sways by swapping from a parts car. I don't believe so. Buddy has a 97 OBS was a different sway bar setup then what I got. On the rear that is. Link to comment Share on other sites More sharing options...
Baddog Posted January 31, 2012 Share Posted January 31, 2012 In for the results! You got me interested now lol I will let you know I am doing a bunch of research. Link to comment Share on other sites More sharing options...
subikid90 Posted January 31, 2012 Share Posted January 31, 2012 I will let you know I am doing a bunch of research. You are the man! We should meet up in a few weeks when I am home. I wont have my legacy but I can take my dads '85 brat lol -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Baddog Posted January 31, 2012 Share Posted January 31, 2012 Sounds good. Hit me up when you're in town. I work out in Tigard now too. At Landmark Ford. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted March 4, 2012 Share Posted March 4, 2012 Question: 2004 WRX STI front and rear Sways. Will they work with my 99' LGT? I can get both for 80.00 Link to comment Share on other sites More sharing options...
Kennyfvholla Posted March 4, 2012 Share Posted March 4, 2012 Question: 2004 WRX STI front and rear Sways. Will they work with my 99' LGT? I can get both for 80.00 Not sure about the front, but the rear will not fit. It isn't designed to fit around the spare tire well in the trunk. Link to comment Share on other sites More sharing options...
subikid90 Posted March 4, 2012 Share Posted March 4, 2012 Front will not fit with an NA crossmember. Rear will fit is you notch the spare tire well. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted March 5, 2012 Share Posted March 5, 2012 Break out the hammer for me. I'll make a notch. Is the front impossible to fit? Link to comment Share on other sites More sharing options...
monkeyposeur Posted March 5, 2012 Share Posted March 5, 2012 We should meet up in a few weeks when I am home. I wont have my legacy but I can take my dads '85 brat lol At the very least take pics of the brat for me! Link to comment Share on other sites More sharing options...
Baddog Posted March 9, 2012 Share Posted March 9, 2012 Decided to just use the 96 legacy C-arms with new whiteline bushings. Too much money invested into fixing it. Wish I could go balls to the wall but I HAVE GOT to fix this damn wheel vibration Link to comment Share on other sites More sharing options...
