Hemp Posted October 4, 2011 Share Posted October 4, 2011 I need to get my main crank wheel off my 97 legacy GT and i dont have this crank wheel rench i need. Anyone have any ideas how to get it off? Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 4, 2011 Share Posted October 4, 2011 Automatic or manual? If it's a manual, just put a socket on the pulley and brace the breaker bar on the frame rail, then bump the starter. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Hemp Posted October 5, 2011 Author Share Posted October 5, 2011 nope its auto. forgot to mention that Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 5, 2011 Share Posted October 5, 2011 Can you get the bolt out, you just want to get the pulley off? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Hemp Posted October 5, 2011 Author Share Posted October 5, 2011 i need to get the pully off. it was put on backwards Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 5, 2011 Share Posted October 5, 2011 How the heck was it put on backwards? Do you not have timing covers on the engine? Pry it off and replace the pulley. A very large gear-puller will do the trick. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Hemp Posted October 5, 2011 Author Share Posted October 5, 2011 The moron that did my head gasket put it back on backwards. Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 5, 2011 Share Posted October 5, 2011 Pry it free and replace it. That's really your best bet. If he put the pulley on backwards, I wonder what else he did? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
xero287 Posted October 5, 2011 Share Posted October 5, 2011 Stick a screwdriver in the flywheel and just break it free with a breaker bar or starter...that works every time for me. Link to comment Share on other sites More sharing options...
xero287 Posted October 5, 2011 Share Posted October 5, 2011 I also recommend replacing your accessory belts as I'm PRETTY sure that the grooves didnt line up correctly since the crank pulley was on backwards. Link to comment Share on other sites More sharing options...
Hemp Posted October 5, 2011 Author Share Posted October 5, 2011 ya the belts are what tipped me off in the first place. I have nice new shiny ones to go on. If i pry it off wont that break the bolt in the center and screw it all together? Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 5, 2011 Share Posted October 5, 2011 Remove the bolt first. I thought you had the bolt off and the pulley was stuck to the crank. Remove the bolt as above. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Hemp Posted October 5, 2011 Author Share Posted October 5, 2011 nope the problem is gettin the bolt off. cant keep the wheel from spinning. Sory for not being clear. im trying to get it off with out taking out my rad if its even possible Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 5, 2011 Share Posted October 5, 2011 What wheel is spinning? The car is in Park, right? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Hemp Posted October 5, 2011 Author Share Posted October 5, 2011 Yea . when i try to remove the nut the whole wheel spins. Its auto so i didnt think i could lock it Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 5, 2011 Share Posted October 5, 2011 Sure you can. Either with a screwdriver in the flex plate, or putting the trans in neutral, unplugging the coil, and bumping the starter with a breaker bar braced against the frame rail. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Hemp Posted October 5, 2011 Author Share Posted October 5, 2011 K ill give a try. Thanks Link to comment Share on other sites More sharing options...
Hemp Posted October 12, 2011 Author Share Posted October 12, 2011 bumping the started worked perfectally. Thank you very much. Its just too bad i totally fucked it. lol. We messed up the timeing then think we hit a valve tryin to get it back. Gotta try a compression test now, but i dont think it will matter. Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 12, 2011 Share Posted October 12, 2011 No problem. Good luck on the rest! [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
cseagle08 Posted October 13, 2011 Share Posted October 13, 2011 I had this same problem when installing a crank pulley on my friends '06 impreza auto. I made up a tool that looked like a giant strap wrench, only with a chain instead of spring-steel. then used an old belt to keep from scratching the pulley. worked like a charm Link to comment Share on other sites More sharing options...
