toolazyforalogin Posted July 10, 2011 Share Posted July 10, 2011 I was just cleaning out my 2007 Legacy (2.5i) and I moved the passenger floor mat out of the car to vacuum the rug. I found this connector sticking out from underneath the carpeting in the back "left" corner undernearth the glove compartment (underneath the center console area). I do not know what this connector (clip) is nor why it would be unclippped. Can any of you experts out there help me to identify what this connector is doing and if I should continue to keep it unclipped? I've attached a few pictures I took with my phone under there. Thanks in advance btw. http://img543.imageshack.us/img543/7135/clip1b.jpg http://img825.imageshack.us/img825/592/clip2f.jpg Link to comment Share on other sites More sharing options...
lgtgirl06 Posted July 10, 2011 Share Posted July 10, 2011 Leave it unclipped. You have to but them together when you are changing the ECU. I don't know what they are called lol. Just leave them alone. Link to comment Share on other sites More sharing options...
toolazyforalogin Posted July 10, 2011 Author Share Posted July 10, 2011 Thanks for the quick response - I'll tuck them back under the carpeting! Link to comment Share on other sites More sharing options...
bmx045 Posted July 11, 2011 Share Posted July 11, 2011 they are test connectors, you connect them when you want to flash the ECU map. Link to comment Share on other sites More sharing options...
Slickvic Posted July 11, 2011 Share Posted July 11, 2011 they are test connectors, you connect them when you want to flash the ECU map. Correct. When you need to reflash your ECU using your AccessPort, you need to connect these. Otherwise Tucky tucky under the carpet. Link to comment Share on other sites More sharing options...
bmx045 Posted July 11, 2011 Share Posted July 11, 2011 Correct. When you need to reflash your ECU using your AccessPort, you need to connect these. Otherwise Tucky tucky under the carpet. Maybe you missed the fact that its an N/A. either way, any ecu map access requires these to be connected Link to comment Share on other sites More sharing options...
lgtgirl06 Posted July 12, 2011 Share Posted July 12, 2011 Maybe you missed the fact that its an N/A. either way, any ecu map access requires these to be connected Now you may be confusing the OP. These do not get connected if not reflashing the ECU. Tuck them back under the carpet disconnected and leave them be. Link to comment Share on other sites More sharing options...
