sambo1 Posted June 18, 2011 Share Posted June 18, 2011 Hi, i have a liberty 97 model that keeps showing overheating problems when its not?? i have changed the thermostat twice (Used original parts), changed the radiator, changed the temperature sender and it doesn't use any water. It will show normal temperature when driving but the moment i stop turn off the engine and restart it to drive again the guage climbs to the very top but the engine is still at normal temp when i check it??? Then if i leave it for an hour or so it is ok again?? Does aanyone have any ideas?? Thanks Sam Link to comment Share on other sites More sharing options...
Osei Posted June 19, 2011 Share Posted June 19, 2011 Tried to search over on Ultimatesubaru essageBoard. Join. Couldn't find the post, but there was a similar issue posted and it turned out to be a faulty temp gauge. O. Link to comment Share on other sites More sharing options...
