01rs25 Posted March 5, 2012 Share Posted March 5, 2012 http://www.infamousperformance.net/servlet/the-253/Whiteline-Subaru-Legacy-GT/Detail Picture isn't right. But whiteline does make an adjustabel rear lat link/control arm for the legacys. Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
Sublimejoe Posted March 5, 2012 Share Posted March 5, 2012 Ah, I see. Thank you! Link to comment Share on other sites More sharing options...
AJW Performance Posted March 5, 2012 Share Posted March 5, 2012 That looks awesome! Cant believe Im so late to the party! Good work sir Link to comment Share on other sites More sharing options...
Sublimejoe Posted March 7, 2012 Share Posted March 7, 2012 Do you suppose by "Whiteline LCA" he means the full lower control arms or the lca brace that they sell? I checked out the link that was posted above but I can't really find any other info on those control arms anywhere. Link to comment Share on other sites More sharing options...
01rs25 Posted March 7, 2012 Share Posted March 7, 2012 http://www.whiteline.com.au/product_detail4.php?part_number=KTA124&sans_vehicle=1 Better example. Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
Sublimejoe Posted March 7, 2012 Share Posted March 7, 2012 http://www.whiteline.com.au/product_detail4.php?part_number=KTA124&sans_vehicle=1 Better example. Excellent! I had just come across an install thread, here. Checking some some shops to see about pricing, because $475... ouch. Link to comment Share on other sites More sharing options...
01rs25 Posted March 7, 2012 Share Posted March 7, 2012 I doubt you'll be able to find them much cheaper then that. Seems to be about the going price for adjustable rear control arms. Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
Sublimejoe Posted March 9, 2012 Share Posted March 9, 2012 I doubt you'll be able to find them much cheaper then that. Seems to be about the going price for adjustable rear control arms. Cool, thanks! Does anyone have any photos of the Outback fenders without flares on them? I am trying to see how extreme of a roll/pull I could get away with without messing up the holes where the flares mount. Link to comment Share on other sites More sharing options...
natoli4 Posted March 9, 2012 Share Posted March 9, 2012 I ended up pulling the plastic flares and cutting and rebending the metal under the plastic. Then painted all the metal so it didn't have any rusting issues. I also had to cut all the plastic trim too on the underside...put it all back together was the hardest part as the plastic has a sticker that needs to be redone...can't even tell either! The cheap plastic inner fender was cut as well...took all day but no rubbing now! Unfortunately the tires rub on the far inside still but only when parking in tight locations... Link to comment Share on other sites More sharing options...
Sublimejoe Posted March 9, 2012 Share Posted March 9, 2012 I ended up pulling the plastic flares and cutting and rebending the metal under the plastic. Then painted all the metal so it didn't have any rusting issues. I also had to cut all the plastic trim too on the underside...put it all back together was the hardest part as the plastic has a sticker that needs to be redone...can't even tell either! The cheap plastic inner fender was cut as well...took all day but no rubbing now! Unfortunately the tires rub on the far inside still but only when parking in tight locations... Awesome! Do you have any photos? How much of the fender would you say you were able to cut away without messing with the places that the flare mounts? What do you mean the plastic has a sticker that needs to be redone? Link to comment Share on other sites More sharing options...
natoli4 Posted March 9, 2012 Share Posted March 9, 2012 no photos, I cut quite a bit on the fender and eliminated one of the fender holes that hold on the plactic fenders. I would say I took out an inch or so...The plastic fender is held on with plastic plugs and double stick (industrial) tape...made by gorilla at home depot...you have to cut 1/8 inch strips and replace it. Link to comment Share on other sites More sharing options...
Sublimejoe Posted March 9, 2012 Share Posted March 9, 2012 no photos, I cut quite a bit on the fender and eliminated one of the fender holes that hold on the plactic fenders. I would say I took out an inch or so...The plastic fender is held on with plastic plugs and double stick (industrial) tape...made by gorilla at home depot...you have to cut 1/8 inch strips and replace it. OK cool, Thanks! Link to comment Share on other sites More sharing options...
natoli4 Posted March 9, 2012 Share Posted March 9, 2012 The way I did it is actually much better than rolling your fender which in the end doesn't give you much more room for travel. The fenders actuallly are rolled outward now after I cut small strips upward in the fender so the two fenders, plastic and metal, cross over each others. Link to comment Share on other sites More sharing options...
jstelll Posted March 29, 2012 Share Posted March 29, 2012 anyway you could get some pictures of your fender modifications? i'll be doing an extreme setup soon as well. Link to comment Share on other sites More sharing options...
Sublimejoe Posted April 1, 2012 Share Posted April 1, 2012 New photos in original post? Also noticed it says STI lip on there and I see a photo of your car with a lip on it. Is that a direct fit? Link to comment Share on other sites More sharing options...
jstelll Posted April 2, 2012 Share Posted April 2, 2012 edit: its a ravspec lip. Link to comment Share on other sites More sharing options...
Bluuu Posted May 11, 2012 Share Posted May 11, 2012 Couldn't imagine that an outback can look as good as this one nice work abbdulcool Link to comment Share on other sites More sharing options...
Sublimejoe Posted June 1, 2012 Share Posted June 1, 2012 Is the lip Legacy GT specific? I didn't think they made an Outback specific one. Link to comment Share on other sites More sharing options...
natoli4 Posted June 1, 2012 Share Posted June 1, 2012 yes for a legacy. got a message from Ravspec that they are out of stock and will be having some new lips in June/July. Link to comment Share on other sites More sharing options...
Sublimejoe Posted June 1, 2012 Share Posted June 1, 2012 Ah ok cool. Do you have any idea if Legacy specific sideskirts will fit on the outback? Link to comment Share on other sites More sharing options...
dylandevine123 Posted June 2, 2012 Share Posted June 2, 2012 pardon teh noob photos... http://i645.photobucket.com/albums/uu178/classified69/DSC_9053-1.jpg http://i645.photobucket.com/albums/uu178/classified69/DSC_9053.jpg http://i339.photobucket.com/albums/n474/abbduljcool/DSC_9492.jpg http://i645.photobucket.com/albums/uu178/classified69/DSC_9315.jpg Love those wheels man really really nice Link to comment Share on other sites More sharing options...
fenominal Posted June 3, 2012 Share Posted June 3, 2012 Stunning! I'm in the process of lowering my wife's OBXT, but I'm stuck on ride height versus wheel and tire size--and what will and won't fit. Didn't think 18x9's would fit, but wow. OP, do you have any rub issues? Link to comment Share on other sites More sharing options...
Sublimejoe Posted June 3, 2012 Share Posted June 3, 2012 Stunning! I'm in the process of lowering my wife's OBXT, but I'm stuck on ride height versus wheel and tire size--and what will and won't fit. Didn't think 18x9's would fit, but wow. OP, do you have any rub issues? There are plenty of threads on here that should help you out. I am running 18x8.5" with absolutely zero rubbing. There is a guy on here running 18x10's too. Link to comment Share on other sites More sharing options...
jstelll Posted June 4, 2012 Share Posted June 4, 2012 There is a guy on here running 18x10's too. ... with absolutely no rubbing. Link to comment Share on other sites More sharing options...
boxkita Posted June 4, 2012 Share Posted June 4, 2012 ^^^^ what size tires? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
