b707guy Posted June 13, 2011 Share Posted June 13, 2011 It's probably right under my big ol Italian nose, but I can't find it! Had misfire cyl 3 code, replaced plugs and wires, code remained, replaced coil, code cleared and no CEL for a few hundred miles. New CEL, code 0325 for knock sensor. Got a new sensor, but... Where the heck is that thing? 98 2.5l LGT Thanks! Link to comment Share on other sites More sharing options...
b707guy Posted June 13, 2011 Author Share Posted June 13, 2011 Well, found the sensor and replaced it. CEL no longer lit, but first drive resulted in pegged temp gauge. This car in our ownership has never overtemped. So I must have done something to cause it? Forgot to reconnect something? I removed the air chamber leading into the throttle body to access the knock sensor, but didn't disconnect any electrics (except the sensor itself) or plumbing other than the hoses that were connected to the chamber. To my knowledge, there isn't an idiot light for high coolant temp, only the gauge, but the supp fans are running now (key in 'on' position), so I'm guessing there really is an overtemp in progress. No steam or anything, yet... Any thoughts? Link to comment Share on other sites More sharing options...
b707guy Posted June 13, 2011 Author Share Posted June 13, 2011 It's usually the obvious - coolant level was too low. Short term problem solved. Now where's the coolant going? Not on the floor, scared of the most likely... Link to comment Share on other sites More sharing options...
Jelousz Posted June 14, 2011 Share Posted June 14, 2011 98/99 High mileage Dual over head cam motors seep coolant into the cylinders. If there is no visible leak, it may be time for new head gaskets. Link to comment Share on other sites More sharing options...
b707guy Posted June 14, 2011 Author Share Posted June 14, 2011 That's kind of what it's looking like... Link to comment Share on other sites More sharing options...
