citka Posted April 27, 2011 Author Share Posted April 27, 2011 I like your reverse lights job. Do they still offer any lighting value at night when you shift into reverse? To answer the question, yes the tail lights in all their forms (turn, brake, marker) are still very visible. They offer a darker tint, but I specifically asked for a lighter tint so as to not interrupt the visibility much. I simply wanted to reduce the contrast between the black paint and the bright red of the tails. Link to comment Share on other sites More sharing options...
Leonardo Posted April 27, 2011 Share Posted April 27, 2011 Thanks! Yes, still visible but I did it because I have bright LED's in the plans for the reverse duties. Link to comment Share on other sites More sharing options...
citka Posted April 27, 2011 Author Share Posted April 27, 2011 Did you cut the film yourself for the reverse lights? Link to comment Share on other sites More sharing options...
Leonardo Posted April 27, 2011 Share Posted April 27, 2011 Yes sir. Link to comment Share on other sites More sharing options...
alaskajoel Posted April 28, 2011 Share Posted April 28, 2011 soooooo hottttt:wub: Link to comment Share on other sites More sharing options...
2000_LegacyOutback Posted May 1, 2011 Share Posted May 1, 2011 drool...... NSX and beautiful subi Link to comment Share on other sites More sharing options...
derkahn Posted May 9, 2011 Share Posted May 9, 2011 nice job man that thing is sweet..looks awesome.!!! yeah lets get a lowered outback pics thread going.. I wish I could get a jdm rear bumper.. wish it came like that from the factory.. yours should be first as its one of the nicest I have seen!! Link to comment Share on other sites More sharing options...
Gire Posted May 9, 2011 Share Posted May 9, 2011 That looks mean as hell. If I had to straight replace my wagon in the near future, I would scour the earth to find a clean OBXT and gather up some similar suspension. Great to see the OB guys in the last few years getting more options of quality lowering products. Id' take advantage too. In a heartbeat. Link to comment Share on other sites More sharing options...
wpmarky Posted May 9, 2011 Share Posted May 9, 2011 sexy subi! Link to comment Share on other sites More sharing options...
easton Posted May 14, 2011 Share Posted May 14, 2011 Citka, great work. I've been trying to figure out a cost effective suspension upgrade for my OBXT and this looks fantastic! Do your tires rub at all with it so low? I've got 48 offset with 245-45-18 and at stock height it only rubs when I make tight turns. Did you have to use any shims to level the height? I will probably use Bilsteins, so I need to figure out what other parts will be necessary. Great work. Link to comment Share on other sites More sharing options...
citka Posted May 17, 2011 Author Share Posted May 17, 2011 No tire rub once I switched to the LGT spec tires. The OB sized tires definately rub. That was a big bummer for me as it makes the speedo off about 6 mph at 70 mph. I'm working on getting that fixed. I've got 1/2" saggy butt shims in the back that I made, but nothing up front other than OEM top hats and LGT spec Swift lowering springs. ZERO rub with the tires I have. Link to comment Share on other sites More sharing options...
MRLancaster Posted June 5, 2011 Share Posted June 5, 2011 We should all get together and start a lowered obxt-only club, call ourselves the Rolling Contradictions. And citka, sweet ride, what are the wheel/tire specs? offset? I'll join! Link to comment Share on other sites More sharing options...
kongzilla Posted June 29, 2011 Share Posted June 29, 2011 Did you have to remove the sub frame spacers or did you just bolt and drop? Alignment out of sync? Are those thing sticking out of your rear trunk your shocks? Link to comment Share on other sites More sharing options...
Sublimejoe Posted June 29, 2011 Share Posted June 29, 2011 I'll join! May I join? I picked up LGT wagon suspension last night and it is currently sitting in my garage waiting to be installed. Link to comment Share on other sites More sharing options...
timmafod Posted June 29, 2011 Share Posted June 29, 2011 Very nice. Link to comment Share on other sites More sharing options...
citka Posted June 29, 2011 Author Share Posted June 29, 2011 Kong - No removal of the sub frame spacers. They actually would make no difference in the height...only in the suspension angle. If you look closely and do the geometry in your head, you'll see those spacers wouldn't effect ride height at all. Alignment was no more out of synch than the LGT wagons I've put the same suspension on (EASY19, TOR and NSFW). A trip to a good alignment shop has worked for all of us very well. No, the things in the rear cargo area are custom build 8" sub woofer enclosures I made...one for each side. Link to comment Share on other sites More sharing options...
Sublimejoe Posted July 4, 2011 Share Posted July 4, 2011 Is your grill just a factory grill painted to match the car? Link to comment Share on other sites More sharing options...
citka Posted July 5, 2011 Author Share Posted July 5, 2011 Yes, it is. I started to go the DIY grill route, but discovered half way through that the LGT grill is different from the OB grill Link to comment Share on other sites More sharing options...
Sublimejoe Posted July 5, 2011 Share Posted July 5, 2011 Yes, it is. I started to go the DIY grill route, but discovered half way through that the LGT grill is different from the OB grill Ahh. I have been trying to figure out if it is different. Thanks! I am going to just have mine painted, along with the chrome trim piece on the hatch. Link to comment Share on other sites More sharing options...
citka Posted July 6, 2011 Author Share Posted July 6, 2011 Having the badge removed and the chrome trim painted is one of my favorite changes. Cleans up the car a lot. Link to comment Share on other sites More sharing options...
Sublimejoe Posted July 6, 2011 Share Posted July 6, 2011 Having the badge removed and the chrome trim painted is one of my favorite changes. Cleans up the car a lot. Did you just remove the badge or did you replace the whole inside of the grill? Link to comment Share on other sites More sharing options...
COmtnBiker Posted July 6, 2011 Share Posted July 6, 2011 Looks great! VERY VERY clean! 2012 Xterra Pro-4X 2003 Outback Sedan Limited D.U.S.T.O.F.F. "Dedicated Unhesitating Service To Our Fighting Forces" Link to comment Share on other sites More sharing options...
citka Posted July 7, 2011 Author Share Posted July 7, 2011 The badge in the front grill is simply painted over. The badge on the rear hatch was removed land the "indent" was filled in then painted. Link to comment Share on other sites More sharing options...
Sublimejoe Posted July 7, 2011 Share Posted July 7, 2011 The badge in the front grill is simply painted over. The badge on the rear hatch was removed land the "indent" was filled in then painted. Awesome, I may have to do that as well. Nobody makes an aftermarket grill for the Outback, correct? Link to comment Share on other sites More sharing options...
titoedge Posted July 7, 2011 Share Posted July 7, 2011 actually... rommel makes/sells a subaru outback grill, he's on the forum. it fits well, and he also recommended a small piece of cardboard to allow the front bumper to 'meet' the grills lower edge perfectly. worked like a charm! Link to comment Share on other sites More sharing options...
