SeeeeeYa Posted April 6, 2011 Author Share Posted April 6, 2011 From a cooling standpoint, the stock IC is better in EVERYWAY vs. the aftermarket. The tinhg the aftermarket ones do is allow more flow with less pressure drop. That is about all. Which actually makes for poorer cooling... Thank you. While the extra psi an aftermarket IC allows makes a difference to a VF40 scratching for every little bit, on a VF52 it does not. The VF52 has a lot more available than a Stg2 can use, and keeping the charge cool is the goal, not hp. An aftermarket IC on my car would "free up" a psi I'd then just have to tune away, to prevent increasing my already 100%+ IDCs. Then, I'd have the same power, but a warmer charge. I'd have increased my weight, raised my CG, and ensured continuous heatsoak in the city... all for only $500-$1200. Until now, however, the 08+ WRX/LGT IC's fundamentally sound quality was overshadowed by its unreliability. No more. Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 6, 2011 Share Posted April 6, 2011 From a cooling standpoint, the stock IC is better in EVERYWAY vs. the aftermarket. The tinhg the aftermarket ones do is allow more flow with less pressure drop. That is about all. Which actually makes for poorer cooling... That actually isn't true. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
mwiener2 Posted April 6, 2011 Share Posted April 6, 2011 +1 The stocker is going to be much better for drag use (unless you ice an aftermarket one first). The aftermarket ones will be much better for road course use. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 6, 2011 Share Posted April 6, 2011 Thank you. While the extra psi an aftermarket IC allows makes a difference to a VF40 scratching for every little bit, on a VF52 it does not. The VF52 has a lot more available than a Stg2 can use, and keeping the charge cool is the goal, not hp. An aftermarket IC on my car would "free up" a psi I'd then just have to tune away, to prevent increasing my already 100%+ IDCs. Then, I'd have the same power, but a warmer charge. I'd have increased my weight, raised my CG, and ensured continuous heatsoak in the city... all for only $500-$1200. Until now, however, the 08+ WRX/LGT IC's fundamentally sound quality was overshadowed by its unreliability. No more. 1) The number of people on this LEGACY board that have VF52's is far less than the number of people on an IMPREZA board. You JUST said that an aftermarket IC makes a difference to a VF40, the turbo that the majority of us have. How can that be, if you ALSO say that the stock intercooler is better in every way than an aftermarket unit? 2) The "extra psi" is not an extra psi. It's one or two psi that aren't lost through the intercooler. That means that you can turn down the boost, have the same manifold pressure, and run cooler! Cooler air in, cooler air out. 3) Datalogs don't tell you anything about components you don't have. Again, you can run 100% IDC's without an intercooler. Does that mean that no intercooler is better than the stock intercooler? 4) In a daily driver, can you feel the difference in CG between a car with a sunroof and one without? No, you can't. No one can. A Sunroof raises the CG much more than an aluminum intercooler does. We aren't talking about 30 pounds, or 20 pounds, or 10 pounds here. We are talking about a marginal weight increase very close to the CG of the car. This is, quite possibly, your worst argument. Do this. Find anyone running a stock intercooler with a 40+ lb-min turbo. Why do you think no one does it? Surely it isn't because of end tanks blowing up. Why are people wasting money on front mount intercoolers, when they can just clamp their stock ones and get away with running GT30R's? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
rao Posted April 6, 2011 Share Posted April 6, 2011 I can absolutely tell the difference between cars that have a sunroof and ones that don't. If you put a dime anywhere in a car that I am driving I can feel the difference int he car's dynamics. It is unfortunate that most drivers are not as in tune as I am. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
mwiener2 Posted April 6, 2011 Share Posted April 6, 2011 Do this. Find anyone running a stock intercooler with a 40+ lb-min turbo. Why do you think no one does it? Surely it isn't because of end tanks blowing up. Why are people wasting money on front mount intercoolers, when they can just clamp their stock ones and get away with running GT30R's? It's because 90% of people will put a new TMIC on because 'that is simply the next step'. You just do that on these cars. Kinda like how it took 6 years to get people to stop doing a CAI as a first mod. And even then alot of people still think a CAI is still a first mod. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
rao Posted April 6, 2011 Share Posted April 6, 2011 I have read that every 10 degree decrease in intake temperature adds like 10 hp. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 6, 2011 Share Posted April 6, 2011 Hmm, the OP did put an AEM CAI on the car after just a few weeks of ownership... [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
rao Posted April 6, 2011 Share Posted April 6, 2011 Have you SEEN the design of the stock intake very restrictive looking. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
goneskiian Posted April 6, 2011 Share Posted April 6, 2011 This has been some interesting reading. SSpeed seems to agree with SeeeeeYa... http://legacygt.com/forums/showpost.php?p=3277905&postcount=3262 Link to comment Share on other sites More sharing options...
bosco Posted April 6, 2011 Share Posted April 6, 2011 Have you SEEN the design of the stock intake very restrictive looking. I have a AEM polished CAI from my '06 LGT for sale if you need it plus it looks cool. Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
rao Posted April 6, 2011 Share Posted April 6, 2011 $5 cash and I can pick it up I think you owe me lunch. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
mwiener2 Posted April 6, 2011 Share Posted April 6, 2011 I'll give you a dime bag for it My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
fahr_side Posted April 7, 2011 Share Posted April 7, 2011 I can absolutely tell the difference between cars that have a sunroof and ones that don't. If you put a dime anywhere in a car that I am driving I can feel the difference int he car's dynamics. It is unfortunate that most drivers are not as in tune as I am. I could tell you whether the dime was heads or tails up. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
Schrei Wolf Posted April 7, 2011 Share Posted April 7, 2011 Hmm, the OP did put an AEM CAI on the car after just a few weeks of ownership... In addition to a CBE, Cobb DB (Possibly UP too: not specified), lowered the temperature under the hood and fender from which the CIA draws from. (Via Ghetto Wrap ) Isn't that the basic fundamentals of boosted power: removing restrictions and lowering temperature? Link to comment Share on other sites More sharing options...
underpowerd Posted April 7, 2011 Share Posted April 7, 2011 Isn't that the basic fundamentals of boosted power: removing restrictions and lowering temperature? i wonder if the world class engineers at fhi might have considered this when designing a compact lightweight intercooler which must sit confined atop a hot engine, often at rest? Link to comment Share on other sites More sharing options...
SeeeeeYa Posted April 7, 2011 Author Share Posted April 7, 2011 I have read that every 10 degree decrease in intake temperature adds like 10 hp. Intake Temperature and Horsepower Loss Estimate power loss or gains due to air temperature changes HP Output = +1% HP per 10 degree temperature decrease -1% HP per 10 degree temperature increase It all adds up. Link to comment Share on other sites More sharing options...
rao Posted April 7, 2011 Share Posted April 7, 2011 Those look like data and facts which I've read aren't important. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
hadvw Posted April 7, 2011 Share Posted April 7, 2011 I could tell you whether the dime was heads or tails up. <topper> I could tell you what year the dime was made. </topper> Link to comment Share on other sites More sharing options...
fahr_side Posted April 8, 2011 Share Posted April 8, 2011 <topper> i could tell you what year the dime was made. </topper> :lol: Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
goneskiian Posted April 8, 2011 Share Posted April 8, 2011 (edited) <topper> I could tell you what year the dime was made. </topper> Oh yeah, I can tell where it was minted! Edited April 8, 2011 by goneskiian Link to comment Share on other sites More sharing options...
bosco Posted April 8, 2011 Share Posted April 8, 2011 (edited) ^ ^ The first liar doesn't have a chance here. Edited April 10, 2011 by bosco sp Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
goneskiian Posted April 9, 2011 Share Posted April 9, 2011 ^ ^ The first lair doesn't have a chance here. Are you calling me a lair? Wait, what's a lair? :lol: Link to comment Share on other sites More sharing options...
mwiener2 Posted April 10, 2011 Share Posted April 10, 2011 I have an evil lair My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
bosco Posted April 10, 2011 Share Posted April 10, 2011 Are you calling me a lair? Wait, what's a lair? :lol: Opps! it should read liar Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
