milesej05 Posted March 25, 2011 Share Posted March 25, 2011 The first thing I noticed while being on the boards here is that Tie rods seem to go bad in the Legacy's. Just curious how you can tell if your tie rod is broke. Also, would this make the car pull a bit to one side or the other? Link to comment Share on other sites More sharing options...
car_cursed Posted March 25, 2011 Share Posted March 25, 2011 you can usually tell a bad tie rod by a clicking noise that can get quicker or slower depending on your speed. and it can throw your alignment out of whack a little. Link to comment Share on other sites More sharing options...
milesej05 Posted March 25, 2011 Author Share Posted March 25, 2011 ok, my car pulls just a tad to the right but I don't hear any clicking noise. I would assume I just need to get my tires rotated or an alignment soon. I am a little over 30K miles without doing the scheduled service as I just bought the car and need to call the previous owner to see if he did the 30K scheduled service Link to comment Share on other sites More sharing options...
joelwatts Posted March 25, 2011 Share Posted March 25, 2011 i just replaced my inners. ima do a walk through on it in a bit. the way you tell is by lifting the front wheels off the ground, grasp the tire at the 3 o'clock and 9 o'clock position. then gently move it back and forth. not enough to turn the wheels just enough to test for play. if it moves, check the end and the inner tie rod for any movement at all. if it moves, its bad. btw, if you hear a clicking noise while turning, its more than likely the axle. not the tie rod. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
joelwatts Posted March 25, 2011 Share Posted March 25, 2011 http://legacygt.com/forums/showthread.php/tie-rod-replacement-diy-158517.html I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
