coz Posted July 23, 2006 Share Posted July 23, 2006 Still awaiting shipment from crutchfield and am curious as to what to expect from the install kit that they threw in for free. Here's a link for the item that they threw in, which seems like a sweet deal as it seems to be the metra one: http://www.crutchfield.com/S-qFwZCPQPIjU/cgi-bin/prodview.asp?i=120998901 Link to comment Share on other sites More sharing options...
mpatch1 Posted July 25, 2006 Share Posted July 25, 2006 Please let me know how you make out - I will be getting an 06 base model with factory sub and wanted to change stereo - Crutchfield says I cannot use the factory sub but I've seen other posts that say I can. Link to comment Share on other sites More sharing options...
coz Posted July 25, 2006 Share Posted July 25, 2006 I will do that. I'm not sure about the factory sub as I don't have that in my car. I'm not home, but apparently the package has arrived this morning. If you do end up going with crutchfield, and you are a first time customer with them, let me know...as they have offered $20 credits for myself and any new customers that I refer to them. Also, if this all goes well, I will have an in working order jazzy board for sale for anyone who's interested. Link to comment Share on other sites More sharing options...
Toronto-Legacy Posted July 25, 2006 Share Posted July 25, 2006 I will definately do that, I'll see how you make out with your stuff and maybe order the kit as well. Will be sometime in September as I need to wait for my sister to go back to Michigan. Â Remember to take lots of pictures! Link to comment Share on other sites More sharing options...
PGT Posted July 25, 2006 Share Posted July 25, 2006 If you're having those kinds of problems, we would be happy to replace it under warranty. The failures you describe are not common. Manville Smith JL Audio, Inc.  Every once in a while, my system won't turn on. turns out that wiggling the CleanSweep plug does the trick. Link to comment Share on other sites More sharing options...
nitegrinder Posted August 16, 2006 Share Posted August 16, 2006 I will do that. I'm not sure about the factory sub as I don't have that in my car. I'm not home, but apparently the package has arrived this morning. If you do end up going with crutchfield, and you are a first time customer with them, let me know...as they have offered $20 credits for myself and any new customers that I refer to them. Also, if this all goes well, I will have an in working order jazzy board for sale for anyone who's interested. Hey Coz! How did that Crutchfield install turn out with the replacement dash panel that they give free with the purchase of a receiver? Have any pics? Are you satisfied? I'm very seriously thinking of going with a Crutchfield deal so if you could tell me what I must do to get you a $20 credit, I'd be glad to do it. I'll be a first time customer. Link to comment Share on other sites More sharing options...
GTS Jeff Posted August 22, 2006 Share Posted August 22, 2006 Here's a picture of mine with the replacement dash panel from installer.com. It's not bad... definitely not as nice as the original factory panel though. It has more of a matte finish, and the factory panel was glossy. It doesn't fit 100% perfectly either, but it's close enough. Do you think giving it some clearcoat beforehand would help? Link to comment Share on other sites More sharing options...
azca Posted June 8, 2007 Share Posted June 8, 2007 Where/how do you plug the FM Modulation in the car? Link to comment Share on other sites More sharing options...
fweasel Posted June 8, 2007 Share Posted June 8, 2007 Where/how do you plug the FM Modulation in the car? There are two types of FM modulators. One has a low power transmitter and antenna built-in and "broadcasts" its modulated signal requiring only power and source signal connections to be made. These are foten found inside of newer satellite radio receivers and MP3 car kits. The second, less expensive, kind plugs inline with the FM antenna to your head unit. They come with a few adapters for the common antenna connections out there. The Subaru HU does not use a standard antenna connector which requires standard plugs to be spliced into place. Kind of a pain. Then the modulator is connecter to 12V and your audio source. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
IB6UB9 Posted August 7, 2007 Share Posted August 7, 2007 Will this work with the '05 LGT? http://www.crutchfield.com/S-qFwZCPQPIjU/cgi-bin/prodview.asp?i=120998901 Link to comment Share on other sites More sharing options...
fweasel Posted August 7, 2007 Share Posted August 7, 2007 Will this work with the '05 LGT? http://www.crutchfield.com/S-qFwZCPQPIjU/cgi-bin/prodview.asp?i=120998901 only if you have manual climate controls, i.e. a 2.5i ignore him, he'll go away. Link to comment Share on other sites More sharing options...
IB6UB9 Posted August 7, 2007 Share Posted August 7, 2007 only if you have manual climate controls, i.e. a 2.5i sorry I'm a noob, but do some GTs have manual climate controls? I thought all GTs had auto dual climate control. What about this installation??? http://www.stimpco.com/d40x/legacy-10-web.jpg Link to comment Share on other sites More sharing options...
gfxdave99 Posted August 7, 2007 Author Share Posted August 7, 2007 I'll respond to your PM publicly so in case anybody else wants to know.... Im running the kenwood HU as the sole source to aftermarket amps and speakers. The HU install isnt that hard you have to vampire tap off the stock stereos power leads etc and then you can install using the avo kit. I got it from avoturboworld.com I dont currently have sat radio but when I do I'll add it directly to the kenwood unit. The stock stereo has no function other then to provide power to the integrated a/c controls. Below is what the faceplate of the stereo looks like and why you cant replace the stock stereo without MAJOR MAJOR custom work. It has been done but its hours and hours and HOURS of delicate soldering that needs to be done by a pro.   http://www.stimpco.com/coppermine/albums/cars/lgtstereo/normal_Stereo-11.jpg sorry I'm a noob, but do some GTs have manual climate controls? I thought all GTs had auto dual climate control. What about this installation??? http://www.stimpco.com/d40x/legacy-10-web.jpg If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
IB6UB9 Posted August 7, 2007 Share Posted August 7, 2007 I'll respond to your PM publicly so in case anybody else wants to know.... Im running the kenwood HU as the sole source to aftermarket amps and speakers. The HU install isnt that hard you have to vampire tap off the stock stereos power leads etc and then you can install using the avo kit. I got it from avoturboworld.com I dont currently have sat radio but when I do I'll add it directly to the kenwood unit. The stock stereo has no function other then to provide power to the integrated a/c controls. Below is what the faceplate of the stereo looks like and why you cant replace the stock stereo without MAJOR MAJOR custom work. It has been done but its hours and hours and HOURS of delicate soldering that needs to be done by a pro.   http://www.stimpco.com/coppermine/albums/cars/lgtstereo/normal_Stereo-11.jpg Vampire tap? God I wish you could post a DIY thread on how to do this. And the AVO kit, can you give a direct link to it on that site? The back of the factory radio looks like death. Link to comment Share on other sites More sharing options...
gfxdave99 Posted August 7, 2007 Author Share Posted August 7, 2007 Vampire tap? God I wish you could post a DIY thread on how to do this. And the AVO kit, can you give a direct link to it on that site? The back of the factory radio looks like death. http://www.avoturboworld.com/avoshop/product_info.php?cPath=1_58_3_62&products_id=228 If you are not familiar with wiring I would have a shop do it for you. If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
dease42 Posted August 7, 2007 Share Posted August 7, 2007 Very nice writeup, answered a lot of questions... unfortunately, a little late for my install, but still ... nice job. I've got the metra dash kit in my 2.5i w/ manual climate controls, and while I agree it's not an exact match, it's pretty darn close.. and I didn't have to wire any circuits  Fantastic call on the depth of the door speakers. Got the Boston S60 components sets a while back, and with both door panels off, and everything disassembled, I realized the speakers wouldn't fit. Drove to the shop with no panels only to find out they didn't have the right spacers. Ended up fabbing my own out of chip-board. Looks and sounds great... gfxDave99 - How did you install the tweeters for the components? Just curious, I replaced the stock tweeters with the Bostons, but the install was a little messy... wondering if there was an easier way... If you're curious, I've got some pics on cardomain: http://www.cardomain.com/ride/2318799 Link to comment Share on other sites More sharing options...
IB6UB9 Posted August 8, 2007 Share Posted August 8, 2007 http://www.avoturboworld.com/avoshop/product_info.php?cPath=1_58_3_62&products_id=228 If you are not familiar with wiring I would have a shop do it for you.  Thanks for the link. I just wish it would let you enlarge the pic more. Do you have any good pics of the setup in your car? I just want to see how the color matches and see how flush it is in the cubby. Link to comment Share on other sites More sharing options...
Kompleks Posted August 28, 2007 Share Posted August 28, 2007 thanx for the info Link to comment Share on other sites More sharing options...
Siper2 Posted October 8, 2007 Share Posted October 8, 2007 I didn't read the whole thread, but Crutchfield does carry a dash kit for the non-turbo models, now ($19.99 - click for link).  http://akamaipix.crutchfield.com/products/2006/120/x120998901-f2.jpeg Link to comment Share on other sites More sharing options...
D_J Posted December 23, 2007 Share Posted December 23, 2007 Subscribe! Glad I haven't done my audio upgrade yet. Still have a lot of homework to do. Plus I have the automatic climate controls (legacy limited) so head unit replacement is not an option. Link to comment Share on other sites More sharing options...
MonkeyHermit Posted December 23, 2007 Share Posted December 23, 2007 Subscribe! Glad I haven't done my audio upgrade yet. Still have a lot of homework to do. Plus I have the automatic climate controls (legacy limited) so head unit replacement is not an option. You might want to check this thread over here. Link to comment Share on other sites More sharing options...
D_J Posted December 27, 2007 Share Posted December 27, 2007 End-up getting a simple add-on for the factory set-up. All I did was add a mono Alpine 450 amp connected to the Alpine Type S 10" Sub. No need for the clean sweep if you keep the factory door speakers from what I was told. The factory built-in EQ settings apparently only apply to the door speakers. From what I can tell, the sub is good to go as is. No need for the clean sweep or even to replace the factory speakers. For wagon owners, the Wicked CAS sub case for $300 seems like a no-brainer. Less than half the cost of the stealth box.  The audio tech felt the quality of the factory speakers was sufficient as is. Otherwise he said if you change the factory speakers out...you'll need to get that clean sweep. Link to comment Share on other sites More sharing options...
msmith Posted December 27, 2007 Share Posted December 27, 2007 End-up getting a simple add-on for the factory set-up. All I did was add a mono Alpine 450 amp connected to the Alpine Type S 10" Sub. No need for the clean sweep if you keep the factory door speakers from what I was told. The factory built-in EQ settings apparently only apply to the door speakers. From what I can tell, the sub is good to go as is. No need for the clean sweep or even to replace the factory speakers. For wagon owners, the Wicked CAS sub case for $300 seems like a no-brainer. Less than half the cost of the stealth box.  The audio tech felt the quality of the factory speakers was sufficient as is. Otherwise he said if you change the factory speakers out...you'll need to get that clean sweep. Suit yourself, but the factory EQ affects the subwoofer's range as well... but it is true that you would need an amp and new front speakers for a Cleansweep to make sense. http://img250.imageshack.us/img250/5995/volcomparedefeated8et.th.gif The blue trace is at Volume "10" The red trace is at Volume "25" The green trace is at Volume "35" (Yes, the description on the graph is wrong) Link to comment Share on other sites More sharing options...
D_J Posted December 27, 2007 Share Posted December 27, 2007 If I had the budget, would do my wagon like yours...just the ultimate set-up. Especially the way your tech soundproofed the doors and used custom speaker grilles.  At least I can always add the clean sweep later and new speakers. JL really seems to dominate the market for the factory interface. For now I got this set-up for about $800 incl installation and the sub case. By the way, the audio shop was an authorized JL reseller - they did a really good job and seemed to be very knowledgable about the clean sweep. Plus they had a ton in stock. Link to comment Share on other sites More sharing options...
D_J Posted December 27, 2007 Share Posted December 27, 2007 msmith - does JL make any type of interface that can connect HD radio to the Subaru factory head unit? From what I hear only aftermarket head units are capable of HD radio. Link to comment Share on other sites More sharing options...
