I can't turn off the alarm. And my car wont start...
Had the car for over two years now and was not aware I even had an alarm system. I disconnected the battery to clean terminals and thats when the alarm sounded. Now I cannot get it to turn off, and I can't start my car without turning it off.
There should be a button that is sort of behind where the lever is to open the hood. I can't remember exactly what you have to do to reset the alarm system but it involves something with that button... Sorry not much help but it's a start!
there is a button up and under the dash on the left...sort of hard to find. just feel around until you find it. push it in and hold it for five to ten seconds. that should reset the alarm and reactivate the fuel pump.
you will want to get a fob and program it.
the other solution to this problem is to have the key in the ignition in the run / on position, put the key in and turn it to start and let it go, and then hook up the battery.
no alarm, no lights and it will start.
