amorgan93 Posted December 17, 2010 Share Posted December 17, 2010 i want to know how using ej205 pistons in my ej22e will affect the compression ratio? lower it, raise it? using the stock heads? i want to run 10psi of boost from a vf20 i have sitting in my basement Link to comment Share on other sites More sharing options...
subikid90 Posted December 19, 2010 Share Posted December 19, 2010 Those pistons wont fit. They are 2.0 pistons in a 2.2 motor. The bore is off, I know the ej22 is a 96.9mm bore, and according to wiki the ej20 has a 92mm bore. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
GEE-OTTO Posted December 20, 2010 Share Posted December 20, 2010 Well you can't use those pistons anyway so there is no guess work about it. Link to comment Share on other sites More sharing options...
