amorgan93 Posted December 16, 2010 Share Posted December 16, 2010 Ive never seen wheel bearings this bad. WOW do i have to replace the whole hub? [ame=http://www.youtube.com/watch?v=DbqNGoh43xo]YouTube - 126 0699[/ame] Link to comment Share on other sites More sharing options...
Legacy Wagon Posted December 16, 2010 Share Posted December 16, 2010 I would. I stress junk parts though cause it's easy enough to change out the hub. Just make sure when you put it back on that you adjust the camber bolts to their respective positions. I believe the FWD's have a slight negative camber adjustment whereas the AWD ones are set to zero. Link to comment Share on other sites More sharing options...
RochNY91TSI Posted December 16, 2010 Share Posted December 16, 2010 Wow, definitely get that replaced asap! Link to comment Share on other sites More sharing options...
Jeffzguy Posted December 16, 2010 Share Posted December 16, 2010 Look and see if the hub moves too. If its the wheel and brakes that wobble its your hub, if the whole hub assembly is wobbling look at the lower balljoints. Link to comment Share on other sites More sharing options...
amorgan93 Posted December 18, 2010 Author Share Posted December 18, 2010 Look and see if the hub moves too. If its the wheel and brakes that wobble its your hub, if the whole hub assembly is wobbling look at the lower balljoints. yall may get a kick out of this. [ame=http://www.youtube.com/watch?v=X_iGKp0MmNg]YouTube - One screwed up wheel bearing!![/ame] Link to comment Share on other sites More sharing options...
Jeffzguy Posted December 18, 2010 Share Posted December 18, 2010 Thats one messed up bearing! Link to comment Share on other sites More sharing options...
amorgan93 Posted December 19, 2010 Author Share Posted December 19, 2010 Thats one messed up bearing! yeah seriously! both front bearings are like that. Does anyone happen to know if the rear wheel bearings on these cars are packable? meaning that i can pack grease in them myself? or are they sealed also? Link to comment Share on other sites More sharing options...
Jeffzguy Posted December 19, 2010 Share Posted December 19, 2010 Just looked at my haynes, the rears area also pressed in. Link to comment Share on other sites More sharing options...
