Yes the up, dp and pretty much any engine mod will work. They both have the same motors. And as far as puttin an exhaust on. A legacy gt exhaust will work you just need longer exhust hangers. I went to pick n pull and snagged some off some jeep cherokees and it worked just fine.
No, make sure the downpipe is correct for an auto or manual transmission, also the rear section is different, unless you get a JDM rear bumper. Manifold, upipe, and midpipe sections should be interchangeable. Most vendors should be able to help answer any questions.
