exhaust problems
Wait you have the Mid pipe and your stock heat shield is prohibiting this? You can Rubber mallet the heat shield at the areas it touches or you can remove it or dremel out the problem area with a cutting wheel attachment.
If you do remove the shielding consider dry wrapping the mid-pipe with thermal wrap. Besides the Drive shaft there isn't much that need protection from heat
thank you sulk, i will PM him and see what it took to have a header built, i have a question about my new exhaust, i have had it on for about 200 miles now and my mpg has dropped by about 5 mpg, i havent been on the gas any more than normal, is this normal or do i need to reset the computer?
Here's the thread with the information of his build.
http://legacygt.com/forums/showthread.php/soooo-bought-ebay-header-147522.html
It doesn't hurt to reset the ecu, just unplug the battery for bit, then plug it back in. ECU will be reset, and it can start learning again.
  • 4 weeks later...
alright does it sound like a honda cause thats what i dont want as long as it sounds decent and almost has some rumble im happy, Did you notice any horsepower gain or loss cause i no a lot of people say that gt cat backs make u lose torque.
i put the whole set up on, and than after about a week i took out the mid and y pipe, i felt a loss with the whole system but with the mufflers seems a little faster but not much. and the sound is great for the 2.5i, it doesnt sound anything like a honda. it has a nice light rumble and lower note than other tuner cars.
