Throttle closing in logs
Types4
The base requested torque value needs to be higher than that in the throttle map or the ECU logic decides you have hit your torque request and reduce the throttle angle a little. You need to keep the values in the 100% column 1 or 2 points higher than the base torque table values.
Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs.
