Moderators BarManBean Posted January 29, 2014 Moderators Share Posted January 29, 2014 Cool. I'm at 14.5R/14.25F, IIRC. So yeah, tire fitment--chop chop! And you have 222k miles on your OBXT? I had no idea! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Scooby2.5 Posted January 30, 2014 Author Share Posted January 30, 2014 Im already at the 14.5 running 245x45x18.5 with 40 offset. I had to roll the rears and really need to roll the fronts a bit. If I were at 15 front and rear, no rolling necessary So what I am saying is I already have the info you need! Link to comment Share on other sites More sharing options...
Robe30 Posted February 3, 2014 Share Posted February 3, 2014 I know the slow part trust me, it's taken me 8.5 years and 222k to get to this point That makes me feel a little better! I'm only 1.5 years in Link to comment Share on other sites More sharing options...
Nightmaresmk Posted August 27, 2014 Share Posted August 27, 2014 Question how was the avo fmic install for the outback. i have it sitting at home waiting to go in. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted September 6, 2014 Author Share Posted September 6, 2014 Love the AVO FMIC.....Use NSFW install thread Link to comment Share on other sites More sharing options...
skrotes Posted March 6, 2015 Share Posted March 6, 2015 Pretty much trouble free, I had a bad wheel sensor once in the winter it was packed with snow. I replaced the turbo at 112,000 BEFORE it would have likely failed. I also had a throw out bearing starting to make noise as it was going bad. So thats when I replaced the clutch. Word to the wise here, if your TO bearing starts making noise in the cold weather or otherwise, get it replaced ASAP, as it will damage the tranny snout if you don't. As soon as mine made noise I yanked the transmission. Other than that not really any other problems. I do use the rack once in a while so really need it to stay..... Hey man I had a question about the problem you had with the tranny. what type of noise will it make when its starting to go? And are there any other signs that it is time to replace the clutch? Link to comment Share on other sites More sharing options...
singincanary Posted April 17, 2015 Share Posted April 17, 2015 How are you liking the Racecomp coils? How's ride comfort? Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 31, 2015 Share Posted May 31, 2015 Scooby do you have any pic's of your AVO FMIC install? like the bumper. My fogs are hitting to the point i can't trim enough and have to remove them. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted June 1, 2015 Author Share Posted June 1, 2015 How are you liking the Racecomp coils? How's ride comfort? Racecomp coils are GREAT!! WAY better than my BC/BR Worth every penny Link to comment Share on other sites More sharing options...
Scooby2.5 Posted June 1, 2015 Author Share Posted June 1, 2015 Scooby do you have any pic's of your AVO FMIC install? like the bumper. My fogs are hitting to the point i can't trim enough and have to remove them. I don't think I do. Ill look around though Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 10, 2015 Share Posted June 10, 2015 Well mine is a redesign it seems and Has some flaws. I had to buy some extra parts to make it work. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted August 16, 2015 Author Share Posted August 16, 2015 Well I had been fighting a misfire cylinder two on my ride. Finally took it down to Cobb in Plano TX for a brush up on the tune and leak down/compression test. Had 60 psi cylinder 2. The others were 150, 144, 140 on a 100K built motor. JE 2618 forged pistons with Crower/Cobb "long" rods. After pulling the motor found a bad exhaust valve causing the 60 PSI. The block was also out .25 so its getting bored to 99.75 Im installing Manley turbo tuff H beam rods and Manley 2618 Platinum pistons 99.75 Selling the Crower long rods and custom JE pistons stock bore pistons. Should have it back around Aug 27th Link to comment Share on other sites More sharing options...
Nightmaresmk Posted August 16, 2015 Share Posted August 16, 2015 Congrats Link to comment Share on other sites More sharing options...
Scooby2.5 Posted August 23, 2015 Author Share Posted August 23, 2015 Picking up the car this week from Cobb Plano Aug 28. Been without it for a couple months so be glad to get back behind the wheel. Updated some specs in initial post Link to comment Share on other sites More sharing options...
Abelr Posted August 26, 2015 Share Posted August 26, 2015 Since you've done the wheel adapters have you had any issues? I'm getting ready to place an order for a set and when reading about the pros and cons most people shy away However I believe with a quality set issues should be minimal. How much did you pay for yours? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted August 27, 2015 Author Share Posted August 27, 2015 No issues at all. The spacers to stay away from are ones that are not hub and wheel centric. They need to have the wheel centric lip for the wheels going on. If its a big "washer" spacer they are no good IMHO. Correct type spacer/adapters are pretty much the same as offset wheels. Don't remember the cost Link to comment Share on other sites More sharing options...
greenchevette Posted August 28, 2015 Share Posted August 28, 2015 Sorry if I missed this... For the STi seat swap; did you bring over the heater elements from your stock seats? Or cut your loses for dat sweet sweet alcantara? Link to comment Share on other sites More sharing options...
greenchevette Posted August 29, 2015 Share Posted August 29, 2015 Sorry if I missed this... For the STi seat swap; did you bring over the heater elements from your stock seats? Or cut your loses for dat sweet sweet alcantara? Researched a bit more last night and saw the long thread or two about this process. I think direct swap 05 LGT Leathers are my answer. Cheers. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted September 12, 2015 Author Share Posted September 12, 2015 Sorry if I missed this... For the STi seat swap; did you bring over the heater elements from your stock seats? Or cut your loses for dat sweet sweet alcantara? I moved the seat heaters over to the STI seats Link to comment Share on other sites More sharing options...
Scooby2.5 Posted September 12, 2015 Author Share Posted September 12, 2015 Researched a bit more last night and saw the long thread or two about this process. I think direct swap 05 LGT Leathers are my answer. Cheers. Yea hopefully you found the thread I posted in. It wasn't as bad as it seems. I mainly wanted to keep the airbags so did the swap over with the LGT seat bottom frame. If I wasn't worried about airbags I would used the 08 up seats as they bolt right in. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted September 12, 2015 Author Share Posted September 12, 2015 Updated Tune Aug 2015 http://legacygt.com/forums/attachment.php?attachmentid=216324&d=1442069821 August 2011 http://accessecu.com/dyno/graph.php?gb=0&hp=1&torque=1&rpm=1&sl=1&sln=1&sat=0&cb=0&dgr=1&smm=0&sg=1&runid1=2785&rgb1=000000255&runid2=2784&rgb2=204000000 Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 12, 2015 Share Posted September 12, 2015 Nice. Surprised you haven't switched to a 440xt or another bigger turbo. you are pushing that 380 for all its worth. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted September 27, 2015 Author Share Posted September 27, 2015 Next year I am going to go 1.5XTR Link to comment Share on other sites More sharing options...
Nightmaresmk Posted September 28, 2015 Share Posted September 28, 2015 That should be a nice bump. As a tomioka racing turbo owner i sugest looking at the TR GT28 comes in lgt format and garret chra. either way should be a nice bump. Link to comment Share on other sites More sharing options...
alex0856 Posted December 19, 2015 Share Posted December 19, 2015 Hey Scooby, quick question. With your first built motor that went 100k - how much power were you pushing with that? Did it have forged internals? Link to comment Share on other sites More sharing options...
