2005 Stage 3 Outback XT STI Seats
Scooby2.5
Updated Build info, picking up car from Cobb Plano Aug 28th with new motor and tune. Car right at 250K
Updated Tune Aug 2015
http://legacygt.com/forums/attachment.php?attachmentid=216324&d=1442069821
August 2011
http://accessecu.com/dyno/graph.php?gb=0&hp=1&torque=1&rpm=1&sl=1&sln=1&sat=0&cb=0&dgr=1&smm=0&sg=1&runid1=2785&rgb1=000000255&runid2=2784&rgb2=204000000
http://legacygt.com/forums/attachment.php?attachmentid=148506&d=1365970937
http://legacygt.com/forums/attachment.php?attachmentid=148518&d=1365974548
Car: 2005 Outback XT
Tuner: Calvin Dotson Cobb Tuning Plano TX
Dyno Info: Mustang
Temp: OLD-55-65F New-65-70
Sea Level: Aprox 1000 FT
Fuel: E85 105 octane/ 93 Octane
PowerTrain:
Tuned by Calvin Dotson Cobb Tuning Plano TX
Cobb Ver 2 AP w Access Tuner Race
350 whp (E85) TMIC 385 whp (E85) FMIC
373 wtq (E85) TMIC 423 wtq (E85) FMIC
304 whp (93) TMIC 350 whp (93) FMIC
317 wtq (93) TMIC 360 wtq (93) FMIC
AVO380 (Garrett 2871r)
AVO Wastegate Actuator
Cobb Turbo Heat Shield
Turbo Blanket
Prodrive EBCS
AVO FMIC
Cobb XLE BOV
AVO BOV Hose
AVO Throttle Body Hose
Cobb Cold Air Intake
Perrin Turbo Inlet
Aeromotive Stealth 340 LPH Fuel Pump
Aeromotive Fuel Pressure Regulator
Aeromotive Oil filled Fuel Gauge
07 STI Fuel Pump Control Module
ID 1000cc Top Feed Injectors and Conversion (Bosch)
Custom Fuel Lines
Cobb Catted DownPipe DEI Wrapped
Cobb Catback LegacyGT 3" Exhaust
Grimmspeed UP DEI Wrapped
Grimmspeed Ported Exhaust Manifolds
Grimmspeed High Flow Crossover DEI Wrapped
Crawford V2 AOS
Cobb Lightweight Crank Pulley
Gates Racing Blue Timing Belt
Grimmspeed Radiator Shroud
Koyo Racing Aluminum Radiator VH2778
Samco Radiator Hoses
Braille B3121 Light Weight Battery
Motul Xcess 5w 40 Synthetic
Cobb Stage 2 Motor- Cobb/Watt Built:
07 STI Block, 07 STI Forged Crank, Manley Platinum 2618 Forged Pistons
Manley Turbo Tuff H-Beam Rods, STI 11mm Oil Pump, Killer B P/U Tube
STI bearings, ARP Rod and Head bolts
Grimmspeed TGV Deletes
DriveTrain:
08 STI 6 Speed
DCCDPro DCCD Controller
08 STI DCCD Switches
07 STI R180 Torsen
08 Spec B Rear Axels
Spec B Driveshaft
STI Spec B Short Throw Shifter
COBB Short Throw Shifter Lever
STI Shifter Bushings
STI Group N Tranny Mount
STI Group N Motor Mounts
STI Pressure Plate
STI Clutch
08 STI Flywheel
Subaru Extra-S gear oil F&R
Suspension:
Cobb Rear Sway Bar
Cobb Front Sway Bar
Cobb Sway Bar Bushings F/R
Kartboy Endlinks F/R
Racecomp Tarmac 1 Coilers
Subtle Solutions 1" lift spacers
Brakes:
Stoptech ST40 BBK
LGT Rear Brake Calipers
Stop tech Street Performance Pads
Stop tech 2 piece rotors Aluminum hats
Centric Rear rotors
Stop tech SS Brake Lines
Motul RB600 Fluid
Audio:
2007 Spec B Radio MP3, Aux Input, Satellite Control
2007 Spec B Console Cubby Aux input for Iphone
Subaru Sirius Satellite Radio Module
Subaru Factory under seat Sub Woofer X2
Interior:
STI Pedals
STI 3 Gauge Pack in Cubby
STI Front Seats 05
STI Alcantara in Rear Seats
Cobb Shift Knob
Spec b shift surround plate STI badge
Redline Leather shift boot
Redline Leather brake lever boot
STI DCCD Controls
Auto dimming Homelink Mirror
Innovate LC-1 Wideband
VBG1 v1.05 AFR and Boost Gauge
Passport X50
Exterior:
Window Tint Front 35% Rear 20%
Volt HID Kit with DRL Disabled
Toshiba HIR High Beams
STI Badge
JDM Outback Bumper with Exhaust Cutouts
Legacy GT Rear Bumper Beam
Michelin Pilot Super Sport Summer Tires
2011 18" STI Enkei Wheels
5x100 to 5x114 15mm Adaptec Speedware/Motorsport-Tech Adapters
Winter Setup: 17" Rota wheels and Blizzack tires 5x100 225x55x17
11143216_508731512636513_529250368861694306_n.jpg.a5a5e474cc3352f99017553fa5b9ce67.jpg
  • Replies 260
  • Created
  • Last Reply
Greg, wow I had no idea you were putting that much work into the OB XT! Aside from the color, I would want everything you've done for my car. Too bad I spend my $$ on other habits. :(
Next step, shave the roof! You don't need that roof rack do you?
Awesome car. Has the car been trouble free on all those 141,000 miles? It looks better than new!
Pretty much trouble free, I had a bad wheel sensor once in the winter it was packed with snow. I replaced the turbo at 112,000 BEFORE it would have likely failed.
I also had a throw out bearing starting to make noise as it was going bad. So thats when I replaced the clutch.
Word to the wise here, if your TO bearing starts making noise in the cold weather or otherwise, get it replaced ASAP, as it will damage the tranny snout if you don't. As soon as mine made noise I yanked the transmission.
Other than that not really any other problems.
I do use the rack once in a while so really need it to stay.....
^ Ive never totaled it up :p, I dont think I want to know. Its been spread out over 6.5 years if thats any consolation. :spin:
I will say this, almost everything on this car was purchased used, or a great deal from a vendor, or Subaru Bucks from using my credit card with work.
My last car a 1997 Jeep Cherokee that was lifted and modded out had 175,000 on it when I sold it on ebay for 9000.
I put that as a big down payment on the Outback when I purchased it.
Its been fun, and I do plan on keeping it for quite some time.
Going to hold off a bit... Got two big projects ahead of me! Took a break from building the wife's wagon to build my car, then I scored a deal on a dyno with Christian from Cobb so now I'm building both! STi seats are still in my future. :D
Very clean outback you have going there. Definently a sleeper. I want that rear bumper if i could ever find one cheap, but i doubt it
japanparts.com
My Install Write Up
http://legacygt.com/forums/showthread.php/jdm-outback-bumper-install-69935.html?t=69935
Its went up a few hundred dollars since I bought it. Plus I got a discount from the OLD prices listed being a LGT member.
  • 3 months later...
Thanks again everyone for the compliments.
Ill be putting the matching Blue Alcantara in the factory back seat cover soon.
I am going to take the stock rear seat covers off and my wife is going to sew the Alcantara in where we take the tweed out.
Ill post pics as soon as I get it done.
