BIGAL8899 Posted November 12, 2010 Share Posted November 12, 2010 wut up?....im kinda new to this whole thing so sry if this is a stupid question. I checked my oil the other day and its 3/4 of the way full on the front side of the dipstick, and full on the backside of the dipstick. I pulled it out and wiped it clean many times. jus wondering how to get the most accurate reading becuase i wanna put just the right amount of oil. Also the manual says to put in 4.2 quarts. Any help would be appreciated. Link to comment Share on other sites More sharing options...
GTTuner Posted November 12, 2010 Share Posted November 12, 2010 You can't. I read both sides, halfway between the high and low side is where your at. Link to comment Share on other sites More sharing options...
mattg Posted November 12, 2010 Share Posted November 12, 2010 I usually run one side at the full and one side near the twist. Our dipstick sucks. Link to comment Share on other sites More sharing options...
Biggu Posted November 12, 2010 Share Posted November 12, 2010 measure out exactly 4.2 quarts and dump it in. but seriously, as long as it reads in between high and low you should be fine. just read it directly off the front side with the markings and it will be as close that will matter. Link to comment Share on other sites More sharing options...
GTTuner Posted November 12, 2010 Share Posted November 12, 2010 INSPECTION Park the vehicle on a level surface.Remove the oil level gauge and wipe it clean.Reinsert the level gauge all the way. Be sure that the level gauge is correctly inserted and properly orientated.Remove it again and check the engine oil level. If the engine oil level is below "L" line, add oil to bring the level up to "F" line.After turning off the engine, wait a few minutes for the oil to return to the oil pan before checking the level.http://www.alldatapro.com/alldata/PRO~V190367371~C42417~R0~OB0~P3R0H~N/0/115013665/117253666/117253857/117253861/34853741/56180732/57395821/34855441/34855448/120289080/120289081 Just after driving or while the engine is warm, engine oil level show in the range between "F" line and notch mark. This is caused by thermal expansion of the engine oil.NOTE: To prevent overfilling the engine oil, do not add oil above "F" line when the engine is cold. Link to comment Share on other sites More sharing options...
PhilT Posted November 12, 2010 Share Posted November 12, 2010 Drain the oil out, measure it, then pour it back in, it's the only reliable way. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
burnout8488 Posted November 12, 2010 Share Posted November 12, 2010 Why do our dipsticks suck so much? I've used ones that make perfect oil lines. My Subaru stick is just as bad as everyone else's - unclear lines, and different on both sides. I never know which one is right. I round up and do 4.5-5 quarts per change. Any extra oil touching the windage tray goes down anyway when the pump sucks it up on startup. Link to comment Share on other sites More sharing options...
BIGAL8899 Posted November 12, 2010 Author Share Posted November 12, 2010 thanks for the feedback... Link to comment Share on other sites More sharing options...
SpecBGuy Posted November 12, 2010 Share Posted November 12, 2010 you need to wait like 10min after driving so you car can cool a little if not ur oil is higher then F mark. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted November 12, 2010 Share Posted November 12, 2010 he said "F mark" but only 10 min like SpecBGuy said so it has time to settle but not get too cool. (Oil, as most things expands when it gets hot and you want to check the level with the engine warm not cold) Link to comment Share on other sites More sharing options...
SpecBGuy Posted November 12, 2010 Share Posted November 12, 2010 he said "F mark" but only 10 min like SpecBGuy said so it has time to settle but not get too cool. (Oil, as most things expands when it gets hot and you want to check the level with the engine warm not cold) F marks the spot:p Link to comment Share on other sites More sharing options...
