mattesonb Posted November 8, 2010 Share Posted November 8, 2010 i know a lot of the 05 -09 LGT parts where similar and some swap directly. would anyone happen to know if a suspension from a 05-09 LGT would be the same as a WRX? Link to comment Share on other sites More sharing options...
AZP Installs Posted November 8, 2010 Share Posted November 8, 2010 I believe the front *May* swap and the rear is similar but I don't know if it's a direct swap. Why not just get the proper WRX stuff? -mike Link to comment Share on other sites More sharing options...
mattesonb Posted November 9, 2010 Author Share Posted November 9, 2010 I believe the front *May* swap and the rear is similar but I don't know if it's a direct swap. Why not just get the proper WRX stuff? -mike It's actually for a 2010 forester Link to comment Share on other sites More sharing options...
BAC5.2 Posted November 9, 2010 Share Posted November 9, 2010 I don't believe either are a direct swap, to tell you the truth. The rear setup is a good bit different, at least comparing the WRX to the LGT. Do you want to put LGT suspension on your 2010 Forester, or do you want to put WRX suspension on your Forester? The latter swaps no problem, the former probably won't. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
URaBusLGT Posted April 1, 2017 Share Posted April 1, 2017 Any luck on finding out if the 08 wrx suspension will swap into the 05 LGT? I'm in the same situation, my brother has a stock 08 WRX suspension he'd give me to put into my 05 LGT if it will work. My suspension is shot. Link to comment Share on other sites More sharing options...
