time4turbo Posted November 8, 2010 Share Posted November 8, 2010 So for us who have the basic stage2 legacy GT ( turbo back exhaust, possibly an intake, and a stage2 tune) and want some more speed without a bigger turbo, let's hear some ideas!...Especially if you have done it yourself and have seen the benefits. ie: lightweight flywheel, e85, etc! Link to comment Share on other sites More sharing options...
Stock_Sucks Posted November 8, 2010 Share Posted November 8, 2010 lazy subcribe:) Link to comment Share on other sites More sharing options...
scoobydoobie Posted November 8, 2010 Share Posted November 8, 2010 UP (if needed), header (GrimmSpeed bits are nice), upgraded TMIC or FMIC, and most importantly TUNE. Link to comment Share on other sites More sharing options...
dmanaenk Posted November 8, 2010 Share Posted November 8, 2010 lose some fat gut interior. 666 Link to comment Share on other sites More sharing options...
Drift Motion Posted November 8, 2010 Share Posted November 8, 2010 UP (if needed), header (GrimmSpeed bits are nice), upgraded TMIC or FMIC, and most importantly TUNE. that Link to comment Share on other sites More sharing options...
Strizzy Posted November 8, 2010 Share Posted November 8, 2010 I wonder what larger injectors and a tune for E85 would net on the stock turbo... You should try it and report back My bad luck build Link to comment Share on other sites More sharing options...
time4turbo Posted November 8, 2010 Author Share Posted November 8, 2010 That's what I was thinking of doing:) Link to comment Share on other sites More sharing options...
Max Capacity Posted November 8, 2010 Share Posted November 8, 2010 Up pipe, tmic and a good tune, is all you need. A good clutch is something to add also. I'm happy with my catless up/dn pipe, tmic, Spec 2+ and a good tune. I spent a hour with my Tuner tweaking the street tune yesterday. At 135,000 miles the car pulls great. I can feel the skin on my face getting pushed back in 2nd gear. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
garygbnj Posted November 8, 2010 Share Posted November 8, 2010 06 lgt. Did the complete sti conversion. Connected the sti tmic with an sti hose (had to cut it to make it fit). Has come off 2x. Is there a better hose or one that is molded to exactly fit this conversion? Just added a spec stage 2 clutch and lightweight flywheel and a vf43 turbo. Faster than the former vf39 but there is a new harmonic at 37-40 mph in 5th gear. Must be the new flywheel. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 8, 2010 Share Posted November 8, 2010 ^You shouldn't be driving in 5th gear at those speeds. I found the same thing a stage 1, when I went to stage 2 that mostly went away. Yes, it is caused by the LWFW. Also when I was at Precision Tuning in Lakewood NJ on Saturday, on there shelf I notice a blue hose that looks like it would fit from the TMIC to the TB. Give them a call, tell them the guy who picked of the tranny on Saturday with the black 5 speed wagon sent you. The hose was out in the area where you first walk in, it's still in the bag. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Ozzy Posted November 8, 2010 Share Posted November 8, 2010 Max, so I shouldn't even be coasting in 5th gear at that speed? Link to comment Share on other sites More sharing options...
RJS5689 Posted November 8, 2010 Share Posted November 8, 2010 Max, so I shouldn't even be coasting in 5th gear at that speed? Sure you can, it just depends on which philosophy of "engine bogging" you subscribe to. Im not sure how different the gearing is on the 6MT vs 5MT, I'm pretty sure your 5th is my 6th, but I can be in 5th at 40 with absolutely no problem. I constantly tach below 2,000 RPM with no problem also. The car doesn't buck around, doesn't struggle and doesn't need to be mashed on to go in that RPM range. Some people tell you that you shouldn't be taching that low, that it's bad for the vehicle, and you should tach higher and be in a lower gear, but I'm not too sure about that. The issue for me with my ACT HD clutch/pressure plate, lightweight flywheel and solid bushings is all the chatter/vibration at the super low RPMs though. Link to comment Share on other sites More sharing options...
rock2534 Posted November 8, 2010 Share Posted November 8, 2010 ^You shouldn't be driving in 5th gear at those speeds. I found the same thing a stage 1, when I went to stage 2 that mostly went away. Yes, it is caused by the LWFW. Also when I was at Precision Tuning in Lakewood NJ on Saturday, on there shelf I notice a blue hose that looks like it would fit from the TMIC to the TB. Give them a call, tell them the guy who picked of the tranny on Saturday with the black 5 speed wagon sent you. The hose was out in the area where you first walk in, it's still in the bag. Did you get your car tuned there?? They are about 2 hours or so from me. Link to comment Share on other sites More sharing options...
05LGTLtd Posted November 8, 2010 Share Posted November 8, 2010 Getting the max out of any turbo is the same. Increase flow and cut drivetrain losses. How much you will gain with a VF40/46 is questionable due to the size of the turbo, but here goes: Intake Port and polish VF40 with ceramic coating TMIC upgrade if goal is response, FMIC if goal is as much power as possible headers/ Grimmspeed ported & coated outlets/x-pipe/up Coated catless 3" straight through turboback exhaust LW Flywheel Lighter Rotors lightest tire/wheel/lugs set-up you can find Custom Tune with Torco blend or race fuel. Really silly things: inlet TGV deletes EWG custom lightweight driveshaft coilpack upgrade LW underdrive pulleys, (yeah it will probably ruin your engine with the LWFW, but as they say you got to play to play) IC cryo setup, IC sprayer, or just move where it is really cold all the time. Strip all extra weight from the car Beyond stage 2: Fuel pump and Upgrade injectors to run E85 stoker 2.7L rebuild with P&P heads Are all these things going to make a difference, no but you would never know until someone did them all and tested it on a known dyno or quarter mile with the right driver. All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
05LGTLtd Posted November 8, 2010 Share Posted November 8, 2010 Make that exhaust a single outlet straight pipe and you can save a few more pounds... ;-) All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
Max Capacity Posted November 8, 2010 Share Posted November 8, 2010 Did you get your car tuned there?? They are about 2 hours or so from me. No just picked up a rebuildable 5MT. I use Mike at Tuning Alliance.com to do my tuning. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
time4turbo Posted November 9, 2010 Author Share Posted November 9, 2010 As far as *practical* weight reduction goes for a daily driver I have heard things like taking out the spare, buying a lighter battery, taking out noise insulation in the trunk.... What other practical things would everyone suggest? Link to comment Share on other sites More sharing options...
time4turbo Posted November 9, 2010 Author Share Posted November 9, 2010 Btw, just to clarify I am talking about legacys which are already satage 2. ie: my stage 2 with a catted downpipe, cat back exhaust and a custom tune from infamous via accessTuner. Just looking for an extra edge to push things a little faster w/o dropping 4 g's on a larger turbo. Link to comment Share on other sites More sharing options...
Drift Motion Posted November 9, 2010 Share Posted November 9, 2010 As far as *practical* weight reduction goes for a daily driver I have heard things like taking out the spare, buying a lighter battery, taking out noise insulation in the trunk.... What other practical things would everyone suggest? take all the useless crap out of your car and lose some weight yourself...lol Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted November 9, 2010 Share Posted November 9, 2010 take all the useless crap out of your car and lose some weight yourself...lol :lol:I've lost a spare tire since joining the forum and I don't mean the one in my trunk!!! Link to comment Share on other sites More sharing options...
BAC5.2 Posted November 9, 2010 Share Posted November 9, 2010 My plan is simple. CNT catted downpipe. IPR TMIC AVO TB hose Grimmspeed Heat Shield PTP Turbo Blanket Custom catback That is all I intend to do for power mods. I'll probably have Infamous tune it. I'd be happy with ~250whp and ~280ft-lbs, which I don't think is unreasonable. I just want something quick enough to stay interesting without being harsh, or aggressive. My ultimate goal is to simply smooth out the drive, especially the low-throttle, low RPM jerkiness. I don't think I'll sacrifice anything in terms of reliability with the above setup. I have a bunch of other stuff waiting to go on the car also, but they'll just make it faster in areas unrelated to power production. They are mostly suspension and brake mods (Bilstein HD's and Brembos). [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
time4turbo Posted November 9, 2010 Author Share Posted November 9, 2010 Anyone added headers and seen much of a difference from them? And FYI I'm 6'4" and 150 lbs.... Not much weight to lose there! Haha Link to comment Share on other sites More sharing options...
Drift Motion Posted November 9, 2010 Share Posted November 9, 2010 Anyone added headers and seen much of a difference from them? And FYI I'm 6'4" and 150 lbs.... Not much weight to lose there! Haha damn...your super skinny im like 5'10" and im 150lb... Link to comment Share on other sites More sharing options...
BruceBruce Posted November 9, 2010 Share Posted November 9, 2010 damn...your super skinny im like 5'10" and im 150lb... your skinny! im 5'10'' and like 205lbs lol Link to comment Share on other sites More sharing options...
robitrice Posted November 9, 2010 Share Posted November 9, 2010 if all you want is speed......buy new gears!? Link to comment Share on other sites More sharing options...
