NSFW Posted January 6, 2012 Share Posted January 6, 2012 Anybody want to try some experimental logging parameters for RomRaider? I can't promise that these will do what they say they will do, but it's worth a try. Unfortunately I don't have an AT so I can't test them myself. Add the XML below to RomRaider's logger.xml file, create a new log profile with all of these plus engine speed (RPM) and throttle plate angle, and log a few seconds of cruising plus a pull. You might not be able to log all of them at once depending on how many other parameters you have selected. You can add these near the top of logger.xml, after the <parameters> line and before the first <parameter> line - the ids won't be in order, but order doesn't really matter. <parameter id="P307" name="NSFW Beta - ATF Temperature" desc="" ecubyteindex="16" ecubit="6"> <address>0x00004D</address> <conversions> <conversion units="raw" expr="x" format="0" /> </conversions> </parameter> <parameter id="P308" name="NSFW Beta - Gear Position" desc="" ecubyteindex="16" ecubit="5"> <address>0x00004E</address> <conversions> <conversion units="raw" expr="x" format="0" /> </conversions> </parameter> <parameter id="P309" name="NSFW Beta - Line Pressure Duty Ratio" desc="" ecubyteindex="16" ecubit="4"> <address>0x00004F</address> <conversions> <conversion units="raw" expr="x" format="0" /> </conversions> </parameter> <parameter id="P310" name="NSFW Beta - Lock Up Duty Ratio" desc="" ecubyteindex="16" ecubit="3"> <address>0x000050</address> <conversions> <conversion units="raw" expr="x" format="0" /> </conversions> </parameter> <parameter id="P311" name="NSFW Beta - Transfer Duty Ratio" desc="" ecubyteindex="16" ecubit="2"> <address>0x000051</address> <conversions> <conversion units="raw" expr="x" format="0" /> </conversions> </parameter> <parameter id="P312" name="NSFW Beta - Throttle Sensor Power" desc="" ecubyteindex="16" ecubit="1"> <address>0x000052</address> <conversions> <conversion units="raw" expr="x" format="0" /> </conversions> </parameter> <parameter id="P313" name="NSFW Beta - Turbine Revolution Speed" desc="" ecubyteindex="16" ecubit="0"> <address>0x000053</address> <conversions> <conversion units="raw" expr="x" format="0" /> </conversions> </parameter> Link to comment Share on other sites More sharing options...
NSFW Posted January 6, 2012 Share Posted January 6, 2012 BTW, in case anyone is interested in where that XML came from, see the last post on the first page of this thread: http://www.romraider.com/forum/viewtopic.php?f=8&t=2991 If it works, Jon [in CT] deserves most of the credit. Speaking of Jon, I haven't seen him posting here in quite a while. Did he buy an Evo or something? Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted January 6, 2012 Mega Users Share Posted January 6, 2012 I'll give em a try. Finally got the ecu updated. It's hard to tell for sure since I went from RT of 408 to 500, but it does seem to be firmer, especially in low to mid throttle. I did some logging, so I just need to flash with the stock RT tables and log some more. Max is still the same. We all confirmed that the max didn't change when we did testing over a year ago, so no surprise there. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted January 6, 2012 Mega Users Share Posted January 6, 2012 NSFW are these different from the ones in the experimental logger defs? Link to comment Share on other sites More sharing options...
NSFW Posted January 6, 2012 Share Posted January 6, 2012 They are not in the experimental logger defs that I posted earlier. I Jon and I came up with them over a year ago, and I had forgotten all about them. In theory they should work for all AT Subarus, so I'll see if I can add them to the official defs if they really do work. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted January 6, 2012 Mega Users Share Posted January 6, 2012 Cool. I added them to the experimental defs, I'll test them out tonight. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted January 7, 2012 Mega Users Share Posted January 7, 2012 They didn't work. The only ones that showed up were the gear position and turbine revolution. I assume the others aren't compatible at all with the 5eat. For some reason, even freessm only shows the solenoids in current or pressure, so I assume that any solenoid PIDs in duty cycle are for other transmissions. But something similar is already in the experimental logger defs. Here's what showed up. Link to comment Share on other sites More sharing options...
NSFW Posted January 8, 2012 Share Posted January 8, 2012 Bummer. Thanks for trying them out, though. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted January 8, 2012 Mega Users Share Posted January 8, 2012 No prob. I'm happy to test things out for you. Link to comment Share on other sites More sharing options...
bmx045 Posted January 8, 2012 Share Posted January 8, 2012 Damnit Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted January 8, 2012 Mega Users Share Posted January 8, 2012 Damnit Dont worry. The experimental defs work. All of those PIDs in that image work except the two that are selected. There is good info, its just hard to get back to back runs that can be compared. Eventually it will happen but i still need to flash the stock rt tables and compare. Still experimentation to do with making the full range of pedal angle at high rt to see what happens. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 9, 2012 Mega Users Share Posted February 9, 2012 I forgot to mention this earlier. Setting the max requested torque with the added definition in efuflash didnt work. I set the max to 500 and it reduced my max throttle plate to around 60%. Back to the drawing board, but the way i had it scaled, the low to mid throttle shifts were much stronger. Im going to play with it some more and make it so the entire throttle plate map ranges from 300 to 406 and see how it works. Link to comment Share on other sites More sharing options...
Black Dragon Posted June 5, 2012 Share Posted June 5, 2012 anynews so far?? Link to comment Share on other sites More sharing options...
bmx045 Posted June 5, 2012 Share Posted June 5, 2012 its been determined that there's a cap in RT that relates to line pressure. i'm at 380 Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted June 5, 2012 Mega Users Share Posted June 5, 2012 This has come as far as it can without someone disassembling the tcu. The wot line pressure wont change from rt, but you can mess with the line pressure at lower throttles. We still don't know how much difference it actually makes, but there is definitely a difference. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted June 6, 2012 Author Share Posted June 6, 2012 This has come as far as it can without someone disassembling the tcu. The wot line pressure wont change from rt, but you can mess with the line pressure at lower throttles. We still don't know how much difference it actually makes, but there is definitely a difference. I hope to eventually get around to measuring the difference in line pressure solenoid duty cycle. Anyone could check it. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
nimrod685 Posted March 19, 2013 Share Posted March 19, 2013 I know i'm bringing up an old thread.. but heres a snapshot of the accesstuner for stage 1 93 map. interesting to look at. so much to learn Link to comment Share on other sites More sharing options...
SiSmoker Posted March 31, 2013 Share Posted March 31, 2013 Hi ClimberD, So I've recently encountered the common gear 2-3 shift shock/hesitation on my 08' Legacy GT. I performed the clear memory 2 with the Vag-com cable and freeSSM and it seems to be re-learning. I did this about 2 days ago. It seems like I'm beginning to see some of the shift shock disappear, but I'm still getting hesitation in certain driving scenarios and the engine is still over revving by about 500-700 rpms when it goes to shift. This usually occurs at high rpms and WOT. The question I'm getting to is, do you think this 2-3 gear change issue could be a line pressure adjust if the relearn isn't taking? Or could it also be the issue of air bubbles in transmission solenoids that need to be purged, and if so, whats the easiest way to purge these lines? I just hope there is an easy solution because I'm actually trying to sell my Subie (sad, I know) and I just want to resolve this one issue before I put it on the market. The transmission has also had the torque converter, valve body and solenoids replaced thanks to the infamous torque converter lock up issue. That was all replaced under warranty and it took Subaru 3 times to get it right. Thanks ClimberD! Your threads have been insanely helpful! Link to comment Share on other sites More sharing options...
fishbone Posted June 14, 2013 Share Posted June 14, 2013 Finally got off my lazy ass and made the changes in my tune. Flashing as we speak, I'll come back with results later. LE: only went through 3 startups and I can tell there is a subtle difference. Seems to have partially taken care of the lazy 1-2 shifts at part throttle. I've made a 30% increase in the tables. On a side note, nice to see I am within 1PSI of my target boost with an intake temp of 110*F Link to comment Share on other sites More sharing options...
fishbone Posted June 19, 2013 Share Posted June 19, 2013 Having done some more driving, I can conclude this tweak did nothing. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted June 19, 2013 Mega Users Share Posted June 19, 2013 I definitely noticed harder part throttle shifts. Exactly what I noticed with the partial throttlehappy tune. I couldn't tell the difference between the two in terms of shifting. Link to comment Share on other sites More sharing options...
fishbone Posted June 20, 2013 Share Posted June 20, 2013 What did I miss then? There are 2 tables to modify, correct? Maybe this is because I already have the IPT valve body mod so I'm running into a mix of TCU programmatic limitations as well as mechanical (valve body needs to be modded further). Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted June 20, 2013 Mega Users Share Posted June 20, 2013 Could be from the IPT. Idunno. Could also be that you're stage 2. Small increases would be more noticeable with less power. It's in no way a major improvement. If it was, there would be more than a few of us messing with it. Did you reset the trans? IMO, you should reset it after a change like that if you want to see a difference. Do the same when you flash back to the original maps for a decent comparison. Link to comment Share on other sites More sharing options...
bigwillystylez Posted July 21, 2017 Share Posted July 21, 2017 Ok.. I know i'm reviving something from the dead... BUT what was the outcomes of this?? Or is there something better now?? Link to comment Share on other sites More sharing options...
