Mega Users seabass07 Posted November 12, 2010 Mega Users Share Posted November 12, 2010 I think the only way to get valuable info from this is to change maps on the same car and compare the two. I'm willing to try it when I can find the time. I'm also fine tuning my stage 1 map, so my limited time is even more limited. I got it to work. The file was somehow corrupted. I downloaded it again and it works perfectly. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 12, 2010 Mega Users Share Posted November 12, 2010 Yes, it's one of those hidden relationships. On the one hand high requested torque may call for increased line pressure in the 5EAT trans. OTOH it can restrict throttle angle to less than 100% in 1st and 2nd gear in a manual. There are still a lot of undefined tables in the ECU logic... what may have no side-effects for the MT guys may be horrible for the 5EAT, and vice-versa. I'm wondering if I'm getting this side effect from these tables or if it is something else with my map. I punch it at 2500 rpm in 3rd and the logs show 85% throttle open angle and it slowly climbs with the revs to 95% at 5500 rpm. It is still much faster than before, but there is definitely something funny going on. Has anyone else logged TPA with these changes to their map? It seems like the car won't exceed around 416 requested torque, so it is not letting the throttle plate go higher. Just a theory, so I changed it to a 30% increase over stock. Hopefully I can flash it this evening. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 12, 2010 Mega Users Share Posted November 12, 2010 hmm. maybe something else going on then. Link to comment Share on other sites More sharing options...
underground000 Posted November 12, 2010 Share Posted November 12, 2010 Maybe cause of the diff tcu for 08+... Also no problems with boost psi, but I can see how RT effects boost targets 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 13, 2010 Mega Users Share Posted November 13, 2010 Hopefully tomorrow I'll have a chance to do some pulls with stock RT and TP maps, then with them increased by 30% and 40%. I'd like to log all of the solenoid pressures for those with freessm as well. I need to pinpoint this. Hopefully I can find the time! Link to comment Share on other sites More sharing options...
ean611 Posted November 13, 2010 Share Posted November 13, 2010 Maybe cause of the diff tcu for 08+... Also no problems with boost psi, but I can see how RT effects boost targets Can you summarize what you've done to your 08? I'm looking for clear instructions so I can work with my tuner on my ROM. Link to comment Share on other sites More sharing options...
_MFB_ Posted November 13, 2010 Share Posted November 13, 2010 Just to share, RT affects boost targets due to the wg tables and target boost table using Torque as its X. So if you ask for a higher torque request via dbw, it wll ask for higher wg and a higher target boost as per the target boost table. I havent come across any proof via logged data that increasing torque request values will have any kind of improvement. Merchgod over romraider specifically posted before not to exceed the highest torque requested value found in your oem map. Its easy to graphically see how the edited dbw map will look like using the workbook made by Airboy over at romraider. Here's the link http://www.romraider.com/forum/topic957.html Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 13, 2010 Author Share Posted November 13, 2010 Pre SI-Drive models are much more simple than that [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 13, 2010 Mega Users Share Posted November 13, 2010 So the strange anomaly I am getting is that when I log RT, at WOT it only goes up to 408 no matter how much I increase it. The throttle plate then follows what would be 408 on the TP map. So if I increase it 40%, the throttle plate will start at 85% and go up to about 95 at redline. If I increase it by 30%, it will start at 95% and go up to 98%. With stock RT and TP tables, the throttle is at 99.8 no matter what RPM at WOT. I logged manifold pressure with both maps. I did two runs with everything the same except the RT and TP maps. The yellow line is with stock RT and TP, the red is increased 30% with the header for the TP increased 30%. These are as back to back as you can get when stopping and re-flashing. The IAT were within 1 deg on both. It only goes up to 5200 rpm in this comparison. I had to slam on the brakes...I never expected a cop to be on a private road:lol: The thing to remember is that even though these are close, the red line starts at 93% throttle and gradually goes up to 99 at 5200. The yellow is 99.8 all the way. http://legacygt.com/forums/picture.php?albumid=766&pictureid=4056 http://legacygt.com/forums/album.php?albumid=766&pictureid=4056 Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 13, 2010 Mega Users Share Posted November 13, 2010 Can anyone with a pre-08 ecu confirm that they can only log RT up to 408? Or confirm the throttle angle reduction? My next step is to do a 27.5% increase over stock which will put the max at exactly 408. I think that will fix the throttle problem. One thing that is becoming clear is that in addition to the extra maps on the 08+ ecu's, it is calculating things differently. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 13, 2010 Mega Users Share Posted November 13, 2010 I don't know anything about the AP. You can in romraider. Link to comment Share on other sites More sharing options...
ean611 Posted November 13, 2010 Share Posted November 13, 2010 Thanks. Will try this soon. Link to comment Share on other sites More sharing options...
_MFB_ Posted November 14, 2010 Share Posted November 14, 2010 These links may provide some info you guys need http://www.romraider.com/forum/viewtopic.php?f=25&t=3846 http://www.romraider.com/forum/viewtopic.php?f=15&t=4426&start=0 http://www.romraider.com/forum/viewtopic.php?f=15&t=5625 Link to comment Share on other sites More sharing options...
tailgatewagon Posted November 14, 2010 Share Posted November 14, 2010 so i gave this a try, results shifts are crisper and pick up off part throtle is much better on a side note if you put in 1.30 in the value box after selecting the entire graph for RT and hit MUL button it will make all the values 30% higher, anyway still loging to see if boost and what not so will report back Link to comment Share on other sites More sharing options...
Black Dragon Posted November 14, 2010 Share Posted November 14, 2010 I'll try it once I got my cable on my 3.0R with SI-Drive Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 14, 2010 Mega Users Share Posted November 14, 2010 Make sure you log requested torque and throttle plate angle to make sure nothing funny is going on there. It will also give you an idea of how it is looking at requested torque. Link to comment Share on other sites More sharing options...
utc_pyro Posted November 15, 2010 Share Posted November 15, 2010 On logging in FreeSSM, log the following: 1,2,3,4,6. Do this in AUTOMATIC mode, and look at the P/L solenoid pressure the closest. If you can get it above 1370kpa in a 05/06, you have managed to raise the line pressure. If the apparent throttle travel just goes to 100% early, then you hadn't done anything to help full throttle. http://legacygt.com/forums/attachment.php?attachmentid=92532&d=1289796611 Quick and dirty way to see if you have bumped up the max pressure: Start FreeSSM with you cable hooked up to your laptop and car. Engin off, ignition on. Click transmission. Click measurements Click the "+" sign Add "P/L Solenoid Valve Pressure" Add "Accelerator Pedal travel" Click "Add" Click "start" Put car in "D" with the motor off and parking break on. Push the throttle to 100% Record the pressure. Flash new throttle/requested torque map. Replete. If you have a higher pressure, this actually works, and you know how much you added. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 15, 2010 Author Share Posted November 15, 2010 Thank you. But... the pressure we are arguably looking for is the amount during a shift. This would require logging. The pressure during steady state cruising would always be around mechanical maximum, no? [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
utc_pyro Posted November 15, 2010 Share Posted November 15, 2010 Thank you. But... the pressure we are arguably looking for is the amount during a shift. This would require logging. The pressure during steady state cruising would always be around mechanical maximum, no? No, it selects the setting based on throttle (or requested torque), not what it's capable of or just when it's shifting. Watching it shift, it looked like it only bumped up the pressure if it was below some threshold map. Otherwise, it just stayed at whatever it came up with for that throttle position in "steady state". There ins't an an analog pressure sensor in the transmission anywhere that we can measure. We can just look at what the TCU is TRYING to do, and see if changing the requested torque makes the TCU try harder. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 15, 2010 Author Share Posted November 15, 2010 Speaking of which, it is entirely possible to hook up a pressure sender to a trans port that is plugged, and log system pressure. I suspect it is the one on the front driver side, but need to check. Either way, it would be a logable representation of the TCU target. Either way, thank you for the write-up and information!!!!!!! [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
fishbone Posted November 15, 2010 Share Posted November 15, 2010 I'm curious what line pressure I'll be seeing with the IPT VB. Link to comment Share on other sites More sharing options...
scoobydoobie Posted November 15, 2010 Share Posted November 15, 2010 hmm so is this something I could get Infamous to tune? He already tuned the car but I may be interested in getting him to adjust line pressure if it can firm up shifts/take a bit of slop out of the shifting. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 15, 2010 Author Share Posted November 15, 2010 I'm curious what line pressure I'll be seeing with the IPT VB. the same requested amount, hopefully a lot more actual [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 15, 2010 Mega Users Share Posted November 15, 2010 Once we all get the kinks out of this and confirm how much of a change it is making without side effects, then maybe. Link to comment Share on other sites More sharing options...
scoobydoobie Posted November 15, 2010 Share Posted November 15, 2010 Once we all get the kinks out of this and confirm how much of a change it is making without side effects, then maybe. Cool, thanks for the reply. I will keep watching and pretending like I know what all this technical talk means Link to comment Share on other sites More sharing options...
