Tmemz Posted October 30, 2010 Share Posted October 30, 2010 So I am driving my car and on applying the break at speeds over 20 mph the wheel begins to shake. At braking with higher speeds it's more violent and I can also feel it in the pedal. Is it the rotors, pads or something else? Link to comment Share on other sites More sharing options...
subie3429 Posted October 30, 2010 Share Posted October 30, 2010 Could be pads or rotors. Link to comment Share on other sites More sharing options...
AZP Installs Posted November 1, 2010 Share Posted November 1, 2010 Most likely pad deposits on the rotors. I would attempt to re-bed the pads again. If that doesn't work then have the rotors turned or replace the rotors and pads. How many miles? -mike Link to comment Share on other sites More sharing options...
Tmemz Posted November 1, 2010 Author Share Posted November 1, 2010 It's got 28k on it. I'm prob gonna turn the fronts because the rears are turned and have new pads Link to comment Share on other sites More sharing options...
robinlsb Posted November 3, 2010 Share Posted November 3, 2010 It's got 28k on it. I'm prob gonna turn the fronts because the rears are turned and have new pads new rotors:) Or maybe the rear rotors:eek: "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
robitrice Posted November 5, 2010 Share Posted November 5, 2010 check your rotors, i used to get this all the time on my lil honda. Sometimes it goes away sometimes it doesnt, but ur brakes are the only thing that make you stop so get it fixed. Link to comment Share on other sites More sharing options...
Triple T Posted November 9, 2010 Share Posted November 9, 2010 I had a front strut that was totally shot, low speed braking wobble and a slight shake at 100 kmh. Replaced both front struts and symptoms gone Hope this helps! BTW, I did the new pads and rotors replacement before the struts... Didn't really help that much, but I can see how new rotors could help if they are warped. Link to comment Share on other sites More sharing options...
