fullerslgt Posted October 30, 2010 Share Posted October 30, 2010 i have a 2005 lgt. ok so i bought my car from a buddy who had the 04 sti brembo kit already on it and now it is time to change the rotors in the rear. i already swapped out the fronts no problem. but because of the unique rotors in the back i am having trouble finding cheaper replacements for the rotors. Fastwrx.com ( http://www.fastwrx.com/brstibrup.html) has them for $578 a pair for the rear. thats not including shipping. i really dont think i want to pay that much for two rotors. i called them and they said that to their knowledge they dont know of any other rotors that will fit the sti calipers and the wrx/legacy parking brake as that is a custom kit. does anyone know of any other fitments for the rear rotors with this conversion kit? thanks. Link to comment Share on other sites More sharing options...
m sprank Posted October 30, 2010 Share Posted October 30, 2010 Brembo is it. I sell them too. But you are going to pay $500 no matter what. Link to comment Share on other sites More sharing options...
wpmarky Posted October 30, 2010 Share Posted October 30, 2010 you could sell your brembo rear calipers and go back to LGT stock rears. Link to comment Share on other sites More sharing options...
yamie700 Posted October 30, 2010 Share Posted October 30, 2010 If I ever get front and rear brembos I'd get rotors from this guy:http://www.knsbrakes.com/searchResults.php?car_id=769 $350 for rears. Link to comment Share on other sites More sharing options...
PhilT Posted October 30, 2010 Share Posted October 30, 2010 Buy regular STi rear discs and get them sleeved to the correct inside diameter. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
m sprank Posted October 30, 2010 Share Posted October 30, 2010 There are many options for conversion kits. They use standard rear rotors. But you need the conversion kit first. Basically brackets. I have the brackets too. But brackets and rotors is about the same as rotors. Only helps if you plan on going through another set of rotors. Link to comment Share on other sites More sharing options...
fullerslgt Posted October 30, 2010 Author Share Posted October 30, 2010 you could sell your brembo rear calipers and go back to LGT stock rears. this crossed my mind. Link to comment Share on other sites More sharing options...
fullerslgt Posted October 30, 2010 Author Share Posted October 30, 2010 If I ever get front and rear brembos I'd get rotors from this guy: http://www.knsbrakes.com/searchResults.php?car_id=769 $350 for rears. so do you know if there will be any fitment issues for these on my 05 lgt? Link to comment Share on other sites More sharing options...
m sprank Posted October 30, 2010 Share Posted October 30, 2010 You need to buy brackets and then you can use those rotors. But it sounds like you already have rear brackets. Since you say you are currently running Rear Brembo calipers. Link to comment Share on other sites More sharing options...
tobey457 Posted October 31, 2010 Share Posted October 31, 2010 Just to clarify - You bought a LGT with a full Sti Brembo swap F/R already installed, now you have to change just the rear rotors? For the rear rotors: did the previous owner go with custom E-brake shoes and stock Sti rotors, or did he go with the stock LGT E-brake shoes and custom adapter rotors? Sounds like the latter... Either way you should be getting out of this well under $500 if you are just looking for rear rotors. KNS sells slotted DBA adapter rotors for the Brembo swap, to work with the stock LGT brake shoes for ~$300 (as mentioned above). It really depends on what's already on the car though. Link to comment Share on other sites More sharing options...
m sprank Posted October 31, 2010 Share Posted October 31, 2010 Sounds like he has the Brembo rear rotors now. So as long as everything is working now, he should be able to use the KNS rotors. This is $350. Link to comment Share on other sites More sharing options...
AZP Installs Posted November 1, 2010 Share Posted November 1, 2010 Yup the KNS rotors are the way to go. OR, perhaps we can work out a swap for my stock rears -mike Link to comment Share on other sites More sharing options...
Submariner Posted November 1, 2010 Share Posted November 1, 2010 There was a guy/company who made extra thick parking brakes shoes so you could use the standard Brembo rear rotor without having to sleeve it. This is the route I took and it works with no problems. I will look at my paperwork when I get home and post who it was. Link to comment Share on other sites More sharing options...
GTurabus Posted November 3, 2010 Share Posted November 3, 2010 There was a guy/company who made extra thick parking brakes shoes so you could use the standard Brembo rear rotor without having to sleeve it. This is the route I took and it works with no problems. I will look at my paperwork when I get home and post who it was. Unclemat Link to comment Share on other sites More sharing options...
