mightymouse Posted October 27, 2010 Share Posted October 27, 2010 Hopefully someone can help me out there. I've changed my lighting to HID and now my low beam on the passenger side flickers on initial startup then stops working, although the drivers side works flawlessly. Also my DRL/ highbeam on the passenger side does not light up anymore but the drivers side does. I tried changing the bulb and no change, I haven't checked the fuse as I assumed the fuse would affect both headlamps. If anyone has any ideas let me know!..also I tried a fused/relayed harness and that didn't work. Link to comment Share on other sites More sharing options...
300zx2g35 Posted October 27, 2010 Share Posted October 27, 2010 There's a fuse for each headlamp so you really might want to check that first. Link to comment Share on other sites More sharing options...
GTS Jeff Posted October 29, 2010 Share Posted October 29, 2010 I haven't checked the fuse as I assumed... Yep. Link to comment Share on other sites More sharing options...
Subiedrew Posted October 30, 2010 Share Posted October 30, 2010 I would look at getting a relay kit for your HID install. I put on in my 06 OBW and it worked much better. Still have to leave my lights on all the time but it's not that big a deal. Link to comment Share on other sites More sharing options...
mightymouse Posted November 2, 2010 Author Share Posted November 2, 2010 thanks for all your help..the problem was solved with a fused relay harness and a 15a fuse for the pass. headlight. Link to comment Share on other sites More sharing options...
