natoli4 Posted April 19, 2011 Share Posted April 19, 2011 19's with 235/45/19 P Zeros. and the winter set up is 17 Rotas with the biggest Yokohama Geolanders that would fit (not sure on size) I have a little rub when I hit a bump mid turn. Megans are too stiff for my liking. good on a highway but city streets are rough. They need to be rebuilt and I'd rather spend the money towards the new suspension . Link to comment Share on other sites More sharing options...
EpicRasta Posted April 19, 2011 Share Posted April 19, 2011 I have a lowered outback and I've never seen one that low. Maybe its actually a Legacy wagon with an outback bumper? Link to comment Share on other sites More sharing options...
Hanger Posted April 19, 2011 Share Posted April 19, 2011 nope, it's a full outback on REEAL BBS LMs ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
lgtftw Posted April 19, 2011 Share Posted April 19, 2011 19's with 235/45/19 P Zeros. and the winter set up is 17 Rotas with the biggest Yokohama Geolanders that would fit (not sure on size) I have a little rub when I hit a bump mid turn. Megans are too stiff for my liking. good on a highway but city streets are rough. They need to be rebuilt and I'd rather spend the money towards the new suspension . What kind of rubbing? is it on the wheel weld liner like others have experienced? I'm actually thinking about running Swift Springs with Legacy GT shocks to see how much rubbing and such I get or even to see if it's possible. Link to comment Share on other sites More sharing options...
natoli4 Posted April 19, 2011 Share Posted April 19, 2011 ya, on the liner...it's only touched a few times (3-5) no damages other than a scuff. Running swift springs on legacy struts is going to make it pretty low. If you consider that the struts themselves lower the car a few inches then the springs lower it another inch...you may have rubbing issues. Link to comment Share on other sites More sharing options...
lgtftw Posted April 20, 2011 Share Posted April 20, 2011 That's what I'm trying to figure out now. I mean, how much more damage could it cost? When I lowered this outback I took a couple of pictures of the struts and what not and when it was done it was hot but he was running the wrong spec tire. If the rubbing is only on the liner that shouldn't be a problem at all. I need to get rid of my LGT first. Link to comment Share on other sites More sharing options...
4RunnerKid Posted April 20, 2011 Share Posted April 20, 2011 and the winter set up is 17 Rotas with the biggest Yokohama Geolanders that would fit (not sure on size) I have a little rub when I hit a bump mid turn Any chance you could find out the size for us? I really like how your OB looks with the bigger meats... Thanks. Link to comment Share on other sites More sharing options...
natoli4 Posted April 20, 2011 Share Posted April 20, 2011 225/60R-17 YOKOHAMA GEOLANDAR A/T-S outside diameter is roughly 1.5" bigger than stock which is basically the biggest I think I can run. when these are on the suspension is adjusted up as high as it will go. Link to comment Share on other sites More sharing options...
4RunnerKid Posted April 20, 2011 Share Posted April 20, 2011 Perfect, thanks man. Link to comment Share on other sites More sharing options...
EpicRasta Posted April 30, 2011 Share Posted April 30, 2011 is it my connection? because i can't see this picture can anyone post a viewable picture? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted June 5, 2011 Share Posted June 5, 2011 Summer and Winter set ups. Megan Coilovers that will be replaced soon with a legacy suspension. Hey get the BC/BR for outback dude, as you know I switched to these on my OB from the megans and love em. I just put kartboy endlinks with the cobb bars and wouldn't go back with the setup I have now. What does your summer setup measure from the ground to the center of the curve in the fender well? How about the OP, what does yours measure from ground to the center of the curve in the fender well? Im getting ready to put an 08 STI Tranny in mine which has 3.90 gears in it. As such I will need to go to the lower profile tire to get back closer to stock ratio (4.44 with taller tires) With that said I will probably lower mine some more when I do the swap. Link to comment Share on other sites More sharing options...
SaggioWRX Posted July 26, 2011 Share Posted July 26, 2011 I'd like to see the pics instead of red X's Link to comment Share on other sites More sharing options...
kongzilla Posted July 31, 2011 Share Posted July 31, 2011 I also have BC on my outback but the ride is a bit harsh for me. Thinking of switching back. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted July 31, 2011 Share Posted July 31, 2011 even on full soft??? Link to comment Share on other sites More sharing options...
kongzilla Posted July 31, 2011 Share Posted July 31, 2011 even on full soft??? lowest setting so far was 3. I might just have do dail it all the way down. I also notice that the travel is really short so when you hit a bump in the road, your suspended in mid air as a passanger. other then that, its pretty smooth and when you really lay on it, its quite nice. Link to comment Share on other sites More sharing options...
NYtoVT Posted November 2, 2011 Share Posted November 2, 2011 Good job, looks good. I'm gonna have to do this since I got rid of my GT wagon for an Outback 2.5i. Link to comment Share on other sites More sharing options...
xLEGACYx Posted November 7, 2011 Share Posted November 7, 2011 Looks awesome! The wheels look great on it. Link to comment Share on other sites More sharing options...
Amoxi Posted August 27, 2012 Author Share Posted August 27, 2012 New pic from the Subaru Challenge over the weekend. Only "new" suspension mods are Whiteline 22mm front and rear sway bars. Still rolling on the stock LGT swapped bits otherwise. Might change that up next spring/summer. Link to comment Share on other sites More sharing options...
OneJay Posted August 28, 2012 Share Posted August 28, 2012 Awesome! I need to go out and do some autox in my wagon too. How do you like the swaybars? Anything noticeably different about them over stock? Link to comment Share on other sites More sharing options...
Amoxi Posted August 28, 2012 Author Share Posted August 28, 2012 It's a pretty significant difference. They're the adjustable Whitelines and I've got them set to firm at the moment. When I get motivated enough this fall I'm going to try the soft setting just to see what it's like. I'd recommend doing it. Link to comment Share on other sites More sharing options...
Amoxi Posted August 28, 2012 Author Share Posted August 28, 2012 Vid of my first run: Link to comment Share on other sites More sharing options...
Alchemist Posted December 5, 2012 Share Posted December 5, 2012 Looks good, just got mine and cant wait to lower it. Link to comment Share on other sites More sharing options...
dvancleve Posted December 15, 2012 Share Posted December 15, 2012 So I am thinking about finally replacing my '97 Outback with an '07 XT. I would want to get it down to about Legacy GT wagon height. Can I run Legacy GT wagon springs with KYBs and still fit stock size Outback XT tires (225/55-R17)? If yes, that is the obvious choice for me. I know on old Outbacks like my current one, Legacy struts will not clear the stock tires but WRX/STi ones will.. Thanks, Doug Link to comment Share on other sites More sharing options...
Scooby2.5 Posted December 15, 2012 Share Posted December 15, 2012 Yes you can Link to comment Share on other sites More sharing options...
DJ DJD Posted February 11, 2013 Share Posted February 11, 2013 I have a set of 05 legacy gt springs i want to put on my 05 xt. do you know if i will need new bump stops or anything? if so, where can i get them? Link to comment Share on other sites More sharing options...
