jeremy_w Posted October 24, 2010 Share Posted October 24, 2010 i met an old friend at a bar last night, and we were talking, and he said he had a 2.5 out of legacy, o rsomething with 200k miles, and i figure i'd buy it, put new rods, rings, pistons in it, if the crank is good, port it a little. i know the EJ engines are nearly identical, so can i use my harness, and computer like i can in my s10 v8 swaps, or do i have to completely re wire it? Link to comment Share on other sites More sharing options...
TK-801 Posted October 24, 2010 Share Posted October 24, 2010 good luck with the project! i would put a v8 in the lego first before the ej haha Link to comment Share on other sites More sharing options...
Zac88 Posted October 24, 2010 Share Posted October 24, 2010 yes very easy just swap over your IM and it should be fine. Link to comment Share on other sites More sharing options...
jeremy_w Posted October 25, 2010 Author Share Posted October 25, 2010 i have the intake mani, throttle body, even the ecu with pigtails. i may just re-ring in and put new rod bearings/mains in if pistons are okay, port the intake manifold, and heads/valve job Link to comment Share on other sites More sharing options...
Zues Marine Posted October 25, 2010 Share Posted October 25, 2010 damn, mr. $$ here haha Link to comment Share on other sites More sharing options...
jeremy_w Posted October 25, 2010 Author Share Posted October 25, 2010 whatchya mean? port intake mani to gaskets, nothing really major. eagle rods, and wiseco pistons about 1k ps, i got the ej25 for free, a WRX driver side seat, and getting rims sometime. Link to comment Share on other sites More sharing options...
Zues Marine Posted October 25, 2010 Share Posted October 25, 2010 head porting runs about $1k alone everywhere i can find Link to comment Share on other sites More sharing options...
jeremy_w Posted October 25, 2010 Author Share Posted October 25, 2010 i mean, a basic gasket to port match, nothing super major. i've ported 5 or 6 small block chevys from 327-420 ci. Now how hard would the head swap be from the 25 to the 22? Link to comment Share on other sites More sharing options...
Zues Marine Posted October 25, 2010 Share Posted October 25, 2010 not hard, and you'll be pushing more power because it'll up your compression a lot too i know you'll need the new intake mani im takin on this project here shortly as well Link to comment Share on other sites More sharing options...
jeremy_w Posted October 25, 2010 Author Share Posted October 25, 2010 it has the intake mani, tb all that stuff, i'll need hgs and al i know, is the ej25 cam better, or the same? Link to comment Share on other sites More sharing options...
Zues Marine Posted October 25, 2010 Share Posted October 25, 2010 they're the same, you'll need to swap to the 2.2 intake mani is what i meant, if you franken motor it Link to comment Share on other sites More sharing options...
jeremy_w Posted October 25, 2010 Author Share Posted October 25, 2010 seems fairly do-able, might be getting a set of 17x8 5zigen rims for 200.00 with kuhmo tires in good shape, rear disk set up for 100.00, hes tryiong to find the pasenger RS seat for me, he also has tokico d spec coil overs for 400.00 never installed! Link to comment Share on other sites More sharing options...
httrdd Posted October 26, 2010 Share Posted October 26, 2010 Who is this guy getting you all the parts??? I want some more! Link to comment Share on other sites More sharing options...
jeremy_w Posted October 26, 2010 Author Share Posted October 26, 2010 he just bought an 2010 evo, and is parting out his wrx track car, has no title, and a hacked out vin so he wants to get what he can out of it. i noticed the 'd specs' had the same color orange ground control sleeves, with red eibach springs, like the kit though. Link to comment Share on other sites More sharing options...
