SebGT98 Posted October 24, 2010 Share Posted October 24, 2010 alright so in the past 2 months i have replaced my front axles, cv joints and boots, hub and bearings, i put coilovers on about a month ago along with the camber kit and allignment. a couple weeks ago i noticed a slight knocking noise when i turned left and can sometimes feel it in the steering wheel, it sounded like it was coming from the front right side, i looked under the car and noticed my tie rod boots were torn apart so i figured it was the tie rods, replaced the tie rods and took a few turns thinking the problem was fixed, now the noise is very consistent, almost every bump in the road makes a loud clunk. my only thought is the strut is blown but i will be very surprised if i broke my brand new coilovers in a month! if any body has any other ideas it would be much appreciated, thanks alot. Link to comment Share on other sites More sharing options...
TbirdMan Posted October 24, 2010 Share Posted October 24, 2010 Check your lower ball joints. either that or an inner tie rod end. could also be a control arm or maybe sway bar bushing? maybe even steering rack bushing? but my first guess is your lower ball joint. Link to comment Share on other sites More sharing options...
Zues Marine Posted October 24, 2010 Share Posted October 24, 2010 mine is the swaybar bushing if not the ball joint Link to comment Share on other sites More sharing options...
jton Posted October 24, 2010 Share Posted October 24, 2010 Sway bar. Link to comment Share on other sites More sharing options...
SebGT98 Posted October 24, 2010 Author Share Posted October 24, 2010 awesome thanks for the advise. i have a feeling its the sway bar Link to comment Share on other sites More sharing options...
snojobz Posted January 3, 2011 Share Posted January 3, 2011 I have a similar clunk coming from my front left corner. I upgraded my sway bars to cusco and had some squeeking from the bushings (upgraded to greasable energy suspension), the squeek went away after about 4k miles and greasing. About 6 months ago I had the control arms replaced due to worn out bushings (54k mi). But lately I have noticed a clunk on almost every left turn. My feeling is the sway bushing is sticking, the new end link is worn (only 6k mi on the new end links and and control arms), or may my struts are wearing out. Any other thoughts? Link to comment Share on other sites More sharing options...
omegax Posted January 16, 2011 Share Posted January 16, 2011 how many miles on your car? Link to comment Share on other sites More sharing options...
snojobz Posted January 16, 2011 Share Posted January 16, 2011 Its an 06 OBWXT with 62k. Link to comment Share on other sites More sharing options...
