Lino Posted October 12, 2010 Share Posted October 12, 2010 Does anyone know what the compression should be on the EJ22 engine, non turbo. My car runs good but I'm thinking the engine is getting worn out and my fuel economy dropping. Maybe I need to do a valve job, do these engines have hydraulic valves also? Link to comment Share on other sites More sharing options...
Zues Marine Posted October 24, 2010 Share Posted October 24, 2010 the 2.2L NA had several compression ratios Phase 1 1995 - 9.5:1 1996-1998 - 9.7:1 Phase 2 1999 - 10:1 HP & tq 1995-1996 - 135HP@5400rpm and 140ftlb@4400rpm 1996-1998 - 137HP@5400rpm and 145ftlb@4400rpm 1999+ - 142HP@5600rpm and 149ftlb@3600rpm in 1997 the 2.2L and 2.5L became interference due to a redesigned piston and higher compression ratio. 1999 Legacys got the phase 1 2.5L(DOHC) while impreza and forester got the phase 2 2.5L(SOHC) Link to comment Share on other sites More sharing options...
Zac88 Posted October 24, 2010 Share Posted October 24, 2010 do you mean compression when your doing a test? IIRC should be about 180psi Link to comment Share on other sites More sharing options...
Yamarocket630 Posted October 29, 2010 Share Posted October 29, 2010 170-180 is about right Link to comment Share on other sites More sharing options...
Lino Posted October 29, 2010 Author Share Posted October 29, 2010 Thanks for the info guys. Link to comment Share on other sites More sharing options...
