jasejase Posted October 11, 2010 Share Posted October 11, 2010 I posted this in another thread, but thought it may be better on its own! just looking for reassurance here! looking to put 18x8 rims (45 mm offset, 5-100) with 225/45 18 tires on them... on an 09 lgt (spec.b). no probelms with this, right?! THANKS Link to comment Share on other sites More sharing options...
jasejase Posted October 11, 2010 Author Share Posted October 11, 2010 anyone? Link to comment Share on other sites More sharing options...
coldradio1 Posted October 12, 2010 Share Posted October 12, 2010 I don't think you will have a problem if you did 225/40/18. 225/45 will be a bit too tall. I have 18x8.5 et48 and I rub very little and I have on a pretty aggressive drop. With the wheels you are looking at, you will get an extra 3mm of play on the outside which is where I have rubbing. I'm also running 0* camber as well. With about a degree, I think I would have zero rubbing. Link to comment Share on other sites More sharing options...
wpgspecb Posted October 12, 2010 Share Posted October 12, 2010 i have 18x8 +48 with 235/40/18 tires and only had to roll the rear fenders, and im not sure if I even HAD to. I never tried the setup before rolling the rears. Fronts fit fine. all stock spec b suspension, stock alignment Link to comment Share on other sites More sharing options...
jasejase Posted October 12, 2010 Author Share Posted October 12, 2010 well. i already have the 225 45 18 tires... and they havent ever rubbed (winter tire)... but they have only been on the stock 18x7 rims... i guess my question is, will the 18x8's change anything fit wise? if they fit and dont rub on the stock rims, they should be fine on the 18X8's right?? from what i gather, and from what tire rack said - they should be fine. Link to comment Share on other sites More sharing options...
coldradio1 Posted October 12, 2010 Share Posted October 12, 2010 My question is, are you lowered? The 18x8's will definitely poke out more compared to the stockers. If you at stock height, you will have no problems. Link to comment Share on other sites More sharing options...
jasejase Posted October 12, 2010 Author Share Posted October 12, 2010 yep all stock Link to comment Share on other sites More sharing options...
wpmarky Posted October 12, 2010 Share Posted October 12, 2010 Here's my car with 18x8 +44 and 225/45/18, lowered on BC Coilovers. 1.5 finger gap all around, 0 camber & 0 toe. No rubbing during hard turns, tires don't hit fender well during big bumps, tho my springs are stiffer than stock (6k/8k) If you're on stock suspension, you should be fine. http://i44.photobucket.com/albums/f37/marky339/NCAL%20Subie%20meet/NCALSubieMeet-31.jpg Link to comment Share on other sites More sharing options...
jasejase Posted October 12, 2010 Author Share Posted October 12, 2010 Thanks! Thats a sweet looking spec.b btw... Link to comment Share on other sites More sharing options...
