ole whore Posted October 11, 2010 Author Share Posted October 11, 2010 ok so i reset the ecu yesterday and then i drove 30 miles to work this morning and did a log....please advise Link to comment Share on other sites More sharing options...
ole whore Posted October 11, 2010 Author Share Posted October 11, 2010 i did not drive past 3500 rpm. Link to comment Share on other sites More sharing options...
Ridgeracer Posted October 11, 2010 Share Posted October 11, 2010 Still alot of knock and IAM/DAM being retarded 93.7% DAM/IAM. It will likely still fall. I don't think that intake is properly scaled and is the culprit. Can really confirm without datalogs and a WB O2 sensor. If your car does not have a tune with a rescaled MAF scale for that intake then reinstall the stock setup ASAP. BTW...Seems the leak you had is fixed or a alot better. Is your commute mixed or straight highway? I will still give all points downstream of the MAF (well mostly after turbo outlet since it was neg correction) a check for leaks and check the vacuum lines for BPV, Fuel pressure regulator, Boost soleniod, Air purge Valve, and manifold pressure sensor. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
Ridgeracer Posted October 11, 2010 Share Posted October 11, 2010 On a tuning note, your engine speed ranges are stupid. I sure hope you don't go above 7500rpm...if not, then that's a wasted row that could be used elsewhere. It's a defined set of tables in RR. That could easily be changed. Not sure if it's defined in EcuTek. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
keithk831 Posted October 11, 2010 Share Posted October 11, 2010 It's a defined set of tables in RR. That could easily be changed. Not sure if it's defined in EcuTek. You're right...it could be changed. Too bad the original tuner didn't do it right. Now the next question is "Has it been this way the whole time?". That's a lot of knock in some key areas. Link to comment Share on other sites More sharing options...
ole whore Posted October 11, 2010 Author Share Posted October 11, 2010 please let me know which parameters to log and i will get it done Link to comment Share on other sites More sharing options...
keithk831 Posted October 11, 2010 Share Posted October 11, 2010 please let me know which parameters to log and i will get it done At least log engine speed, engine load (2-byte), throttle opening angle, knock sum, fine learning knock correction, and manifold relative pressure. Link to comment Share on other sites More sharing options...
ole whore Posted October 11, 2010 Author Share Posted October 11, 2010 will do... Link to comment Share on other sites More sharing options...
SonicSpecB Posted October 11, 2010 Share Posted October 11, 2010 No knock on my car i use the same fuel he does,Doubt that IAM will rise most likely fall.Go back by Jason and let him rescale that MAF. Link to comment Share on other sites More sharing options...
ole whore Posted October 11, 2010 Author Share Posted October 11, 2010 No knock on my car i use the same fuel he does,Doubt that IAM will rise most likely fall.Go back by Jason and let him rescale that MAF. jason said the maf was rescaled to suit my intake.....he said my turbo intake tube my be the culprit ?? Link to comment Share on other sites More sharing options...
m sprank Posted October 11, 2010 Share Posted October 11, 2010 Could have a leak. Link to comment Share on other sites More sharing options...
SonicSpecB Posted October 11, 2010 Share Posted October 11, 2010 jason said the maf was rescaled to suit my intake.....he said my turbo intake tube my be the culprit ?? Good at least its narrowed down,fix it asap and let us know. Link to comment Share on other sites More sharing options...
ole whore Posted October 11, 2010 Author Share Posted October 11, 2010 ^^^will do... Link to comment Share on other sites More sharing options...
Ridgeracer Posted October 11, 2010 Share Posted October 11, 2010 Turbo inlet tube leak will not give you negative correction. If you have stock injectors, no leaks in the system, the intake should be very easy to scale. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
keithk831 Posted October 12, 2010 Share Posted October 12, 2010 Turbo inlet tube leak will not give you negative correction. If you have stock injectors, no leaks in the system, the intake should be very easy to scale. When my inlet tube went bad my airflow readings were all over the place...rich and lean. P.S. I don't see the MAF scaling as the only culprit here. You still have some major issues to work out. As has been said above, check again for leaks. Link to comment Share on other sites More sharing options...
NSFW Posted October 14, 2010 Share Posted October 14, 2010 I see two ways this thread might evolve: 1) The tune is good but the car has a leak. Ole Whore needs to find the leak, fix it, and validate (with LV) that the car is healthy. 2) The tune just sucks. The car will slowly self-destruct until/unless an EcuTek tuner fixes the tune, or Ole Whore sends the ECU to Tactrix to have EcuTek removed (about $75+shipping) and then has an EcuFlash tuner do what it takes to give it a proper tune. Link to comment Share on other sites More sharing options...
ole whore Posted October 14, 2010 Author Share Posted October 14, 2010 I see two ways this thread might evolve: 1) The tune is good but the car has a leak. Ole Whore needs to find the leak, fix it, and validate (with LV) that the car is healthy. 2) The tune just sucks. The car will slowly self-destruct until/unless an EcuTek tuner fixes the tune, or Ole Whore sends the ECU to Tactrix to have EcuTek removed (about $75+shipping) and then has an EcuFlash tuner do what it takes to give it a proper tune. i think it's the first one ... i'm just changing some vacume hose and my turbo inlet tube looks swollen and looks like it has a very small hole , so i ordered one . just waiting on it and will update asap. Link to comment Share on other sites More sharing options...
ole whore Posted October 24, 2010 Author Share Posted October 24, 2010 got the turbo intake tube and will install tomorrow. should i check anything else while i'm removing the oem intake tube ?? Link to comment Share on other sites More sharing options...
keithk831 Posted October 24, 2010 Share Posted October 24, 2010 got the turbo intake tube and will install tomorrow. should i check anything else while i'm removing the oem intake tube ?? Just make sure everything is attached the way it should be. Link to comment Share on other sites More sharing options...
ole whore Posted October 25, 2010 Author Share Posted October 25, 2010 should catch cans be installed at this time also ?? Link to comment Share on other sites More sharing options...
NSFW Posted October 26, 2010 Share Posted October 26, 2010 I lean towards not changing anything until you've got this problem figured out. Otherwise you're likely to get into a situation where you've got more than one thing wrong, and it's impossible to tell when you've fixed one thing, because some other thing is still making the car run like crap. Not fun to diagnose. Link to comment Share on other sites More sharing options...
ole whore Posted April 28, 2011 Author Share Posted April 28, 2011 ok , so it been awhile since i post here but car was down and alot of work went into it. with regards to the cause of the original problem, the intake tube had a small hole but the intercooler pipe to the trottle body had a half ince diameter hole. so that was the main problem , all fixed and the car runs well now. thanks for all the help. Link to comment Share on other sites More sharing options...
Deaks2 Posted April 28, 2011 Share Posted April 28, 2011 Very cool. Post up an LV after you've driven around a bit. I am curious as to the cause of your pulled timing. An intake leak should not cause that much knock. Link to comment Share on other sites More sharing options...
