slvrlegacygt Posted October 9, 2010 Share Posted October 9, 2010 I was trying to install Eibach springs on my 07 spec B which was a major fail. After I reinstalled the passenger side strut the only one i removed i noticed a puddle of fluid on the ground, after inspection i came to the assumption it has to be from the transmission because it was clear and somewhat odorless....after that right away i put the car up on jack stands and took some pics. These are taken from the passenger side. I hope i didn't damage someting and this can be fixed somewhat easily. Link to comment Share on other sites More sharing options...
technicalgarage Posted October 9, 2010 Share Posted October 9, 2010 just push the axle back in and top off the fluid. hopefully you didn't damage a seal or anything. Link to comment Share on other sites More sharing options...
BruceBruce Posted October 10, 2010 Share Posted October 10, 2010 if it was transmission fluid that stuff would stink bad. just an FYI Link to comment Share on other sites More sharing options...
burnout8488 Posted October 10, 2010 Share Posted October 10, 2010 You really need to crank on the hub to be able to pull an axle out like that without removing it from the hub first... definitely a major fail. How exactly were you going about doing the lowering springs? I've never heard of this happening before. Hell, I never even thought this could be possible given the number of times I've had my struts off. Link to comment Share on other sites More sharing options...
jagcars26 Posted October 10, 2010 Share Posted October 10, 2010 . How exactly were you going about doing the lowering springs? I've never heard of this happening before. Hell, I never even thought this could be possible given the number of times I've had my struts off. I'm with burnout,how the f*** did you do this changing out springs? Link to comment Share on other sites More sharing options...
slvrlegacygt Posted October 11, 2010 Author Share Posted October 11, 2010 i was so intent on changing the spring that i forgot to support the hub assembly and it leaned away from the car...thats really the only thing i can think of because i didn't really pull on it. I definately pushed on it though to line up the bolts for the strut. I also tried just pushing it back in and it doesnt want to move any tips or ideas? What kind of fluid am i replacing it with and where do i add it? Link to comment Share on other sites More sharing options...
slvrlegacygt Posted October 12, 2010 Author Share Posted October 12, 2010 i got the axle back in, i had to remove the bolts in the strut on top and the bottom to get the hub assembly to move freely. Once it was free i just pushed the assembly towards the center of the car and the axle went right back in. I realized the fluid that leaked was the differential oil. Does anyone know where i can buy subaru extra s gear oil in quarts and not the 5 gallon drum for $150? Link to comment Share on other sites More sharing options...
robbie_R Posted October 13, 2010 Share Posted October 13, 2010 Try turninconcepts.com they used to sell it per qt. I see how this could happen with the strut out and knuckle loose. I've never actually seen it happen though. Link to comment Share on other sites More sharing options...
slvrlegacygt Posted October 14, 2010 Author Share Posted October 14, 2010 checked their website and it doesn't look like they sell extra gear-S oil Link to comment Share on other sites More sharing options...
robbie_R Posted October 15, 2010 Share Posted October 15, 2010 Guess they don't anymore. Well they come in a 18.9L keg so if you can round up a few guys that would like some for top off. Link to comment Share on other sites More sharing options...
