njwrestler07 Posted October 8, 2010 Share Posted October 8, 2010 I was thinking of buying a LGT or the Legacy 3.0R, the problem with the 3.0R is the auto transmission, if i wanted to swap to a manual 6-speed trans, what would something like that cost? Link to comment Share on other sites More sharing options...
Kw521 Posted October 8, 2010 Share Posted October 8, 2010 Usually you can get the 6spd complete from What Ive see for about three grand used. Idk how it would bolt up to the 3.0r but the LGT it would be okay. Link to comment Share on other sites More sharing options...
njwrestler07 Posted October 8, 2010 Author Share Posted October 8, 2010 thanks for the input, im just unsure of which car to buy right now Link to comment Share on other sites More sharing options...
Strizzy Posted October 8, 2010 Share Posted October 8, 2010 If you plan to mod for power, then go with the 2.5 turbo over the 3.0. My bad luck build Link to comment Share on other sites More sharing options...
Max Capacity Posted October 8, 2010 Share Posted October 8, 2010 X2 the 2.5 turbo has much more potential and there are all kinds of aftermarket support for it. The 3.0 is something your mom would drive. To swap a manual onto a 3.0 could cost 5 or 6 grand by the time it's all done, if it could be. It's not something that's commonly done. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
