Dragevo Posted October 5, 2010 Share Posted October 5, 2010 Hi, all - my first post here I'm having problems with my Legacys' transmission. It makes bad noises when it's cold, while the noises are almost non-existent when it has warmed up. I ruled out the CV joints, so today I ripped the tranny apart. I found that the main clutch/clutch assembly has lots of play in it, and I don't think this is normal... Please have a look at the short vid I did, and tell me what you think - I really need a 2nd opinion on this. [ame=http://www.youtube.com/watch?v=gy6zLQgeY1o]YouTube - Subaru 4eat transmission problem.[/ame] Thanks Link to comment Share on other sites More sharing options...
Dragevo Posted October 6, 2010 Author Share Posted October 6, 2010 This nut is the only real challenge so far, as it's really tight in there. I must remove it, to be able to get the shaft & the big drum out - and also to pull the front pump / front cover off. Now I need to find or make a spanner for that nut. Link to comment Share on other sites More sharing options...
