need bb Posted October 5, 2010 Share Posted October 5, 2010 I have a stage 2 tune by Infamous and the car has been running great, but the car the throttle response engaging the clutch has always been difficult. I know the car isn’t NA, but under 2K there is a half second delay between pushing the accelerator down and having the engine respond. Is anything I can do in the tuning department to help the throttle responding when engaging the clutch so the RPM’s don’t jump around so much? Thanks Link to comment Share on other sites More sharing options...
elpete77 Posted December 3, 2010 Share Posted December 3, 2010 i was hoping for an answer also, just went cobb stg2 91 oct, it's not so much throttle response as a delayed throttle engagement, like i have to push the pedal down a lot more for any throttle response. Link to comment Share on other sites More sharing options...
underground000 Posted December 3, 2010 Share Posted December 3, 2010 lightweight crank pulley or flywheel? my 5eat seems more responsive less hesitation from a stop w/ a lw crank pulley delay before response can be from drive by wire 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
rock2534 Posted December 3, 2010 Share Posted December 3, 2010 I think I know what you are referring to, I feel it in regular sport mode, but in sport sharp mode the response is much faster. I see you have an 05 so you don't have the SI drive to try it. I remember seeing the different settings in the map for each SI setting in romraider, so I would think you could just adjust your settings too. However I would leave that for someone who knows what they are doing. Link to comment Share on other sites More sharing options...
brum Posted December 3, 2010 Share Posted December 3, 2010 Light weight flywheel is the ticket IMO. I went from the stock dual mass to a Spec 15 lb flywheel. It's pretty noticeable. But also remember that this is a low compression turbo motor and the "NA aspect" of it will seem pretty crappy. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted December 5, 2010 Share Posted December 5, 2010 it's all in your head. you have unrealistic expectations for this type of turbo vehicle On the search for a new DD... Link to comment Share on other sites More sharing options...
keithk831 Posted December 5, 2010 Share Posted December 5, 2010 Low-end timing may be a little too low. Link to comment Share on other sites More sharing options...
rtbrjason Posted December 5, 2010 Share Posted December 5, 2010 I'm not sure what to think.. Why would you need throttle response under 2k rpm? Downshift into your power band if you want throttle response. 1600-2400 rpm is more ideal for maintaining your speed than accelerating. If you're talking about just moving through that range in normal driving, then you could talk to your tuner about upping the throttle mapping a bit in those areas. Even in normal driving though, you should only be at that low of an rpm in the first couple of gears, and briefly at that. Link to comment Share on other sites More sharing options...
