Jeffzguy Posted October 1, 2010 Share Posted October 1, 2010 Just replaced my passenger front CV, balljoint, rotor, lug studs and lugs and now I get a little wobble and maybe a little grinding when I turn left, but only sometimes, not sure if I messed up or if something could be off balance? Link to comment Share on other sites More sharing options...
sqc151 Posted October 1, 2010 Share Posted October 1, 2010 jack the car up and check your hubs. also remove the wheel and make sure the axle nut didnt come loose after you drove it. Link to comment Share on other sites More sharing options...
Jeffzguy Posted October 1, 2010 Author Share Posted October 1, 2010 Just did, nothing looks wrong, everything has been tourqued and re-tourqued... I dont get it. Maybe its from something else? Also do you know anything about speakers for these cars? Link to comment Share on other sites More sharing options...
Legacy Wagon Posted October 8, 2010 Share Posted October 8, 2010 Make sure you set your camber right with that top bolt if you took the hub off. Link to comment Share on other sites More sharing options...
Jeffzguy Posted October 8, 2010 Author Share Posted October 8, 2010 No I did it via pulling balljoints because I was replacing them anyways. Link to comment Share on other sites More sharing options...
