thebigevilfoot Posted September 29, 2010 Share Posted September 29, 2010 Does a catless UP cause a CEL? Thanks. Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted September 29, 2010 Share Posted September 29, 2010 Yep. 1. Click FORUM 2. Click WALKTHROUGH:PERFORMANCE MODS 3. Scroll through the list..choose "The Unofficial 05-06 LGT 2.2k .5w Resistor UP Pipe Install CEL FIX" by LosAngelesGT, nice write up. http://legacygt.com/forums/showthread.php/unofficial-05-06-lgt-2-2k-5w-resistor-up-pipe-install-cel-131488.html?t=131488 As an alternative you can have your tuner disable the code in your tune. I did both. Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted September 29, 2010 Mega Users Share Posted September 29, 2010 Only if it is installed.... Ok fine. The OEM uppipe, that has a catalytic converter in it is monitored by an EGT Sensor which is read by the ECU to make sure the the CC is operating correctly. When you remove this sensor either by unplugging it or just leaving it hanging out of the exhaust stream, the ECU will know something's up and will throw a CEL. Search "resistor mod" and that will more completely answer your question. And you're stage 2 already? I hope you have said catless uppipe Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted September 29, 2010 Mega Users Share Posted September 29, 2010 Ok yeah, that took me 4 minutes to type, so what Lieutenants REPRESENT Link to comment Share on other sites More sharing options...
thebigevilfoot Posted September 29, 2010 Author Share Posted September 29, 2010 Car is back stock and going to the dealership. I didn't want to invest any money, so I was able to take out the DP and CBE myself, but I don't think I can do the UP, so I want to bring the car into the dealer without a CEL. Currently my car is throwing that my 02 sensor is broken, but I think I fixed the 02 sensor, the wire was cut, so I just rewired it. What I did was, I simply put my tune back so that the CEL goes away, but I think this resistor idea is a better/safer plan so I don't blow my car up with a 17.5 psi tune. My plan was to just drive around without hitting boost. Link to comment Share on other sites More sharing options...
