Th3Franz Posted September 28, 2010 Share Posted September 28, 2010 I've been running the original battery in my car since I bought it. So, it's been over 6 years now. It's not doing so great, so I am thinking about getting a new lightweight battery, similar to the one in this thread. http://legacygt.com/forums/showthread.php/lightweight-battery-installation-20-lbs-front-120650.html?t=120650 But, I want to take it one step further and relocate the battery. I haven't looked really closely yet, but either behind the rear seat or in the spare tire well in the trunk. Why relocate the battery? A few reasons.. -I'm electrically inclined. It wouldn't be difficult to run a large fused wire from the trunk area to the engine bay. -Better weight distribution. -40 lbs off the front of the car while adding 20 lbs or so to the middle and back in wire, mount, and battery. -I'm due for a new battery anyway, so it's the perfect time to do this. -Heat is a battery killer. Getting the battery out of the engine bay will improve the longevity, even for sealed AGM batteries. Any input on where I should mount the battery in the middle or rear (trunk) of the car? I think I'll get either an Odyssey PC680 or their ER30 racing battery. The ER30 is more expensive but it's extremely heavy duty and has the most CCA of any other 20 lb battery. It gets pretty cold here. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Th3Franz Posted September 28, 2010 Author Share Posted September 28, 2010 reserved if I make this a walkthru -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
MassiSandage Posted September 29, 2010 Share Posted September 29, 2010 I plan on using the flat braided cable on mine. That will make it easy to fasten to the car as you can separate the braid and use a screw/washer at any point in the cable, which will also serve to help ground the system at numerous points along the cable. When I get close to the computer I plan to solder a smaller piece of braided cable into the larger main braided cable and run it directly to the computer.... ______________ Download Vlc Player Link to comment Share on other sites More sharing options...
Roja618 Posted September 29, 2010 Share Posted September 29, 2010 Subscribed. Thinking about doing this as well. Just looking around for rough guidelines. Link to comment Share on other sites More sharing options...
spec.B Dream Posted January 16, 2011 Share Posted January 16, 2011 Curious if you ended up going with the relocation. Link to comment Share on other sites More sharing options...
rao Posted January 16, 2011 Share Posted January 16, 2011 1. You don't have to run the ground to the front of the car. 2. Moving the battery will make no difference in handling, at least not on a car that a V-6 mustang will destroy at the track 3. Those little batteries are a really bad idea anywhere and especially anywhere in Wisconsin 4. If you think 6 years is too short of a battery life, you are nuts Relocating a battery Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
dr_sharp Posted January 16, 2011 Share Posted January 16, 2011 2. Moving the battery will make no difference in handling, at least not on a car that a V-6 mustang will destroy at the track 3. Those little batteries are a really bad idea anywhere and especially anywhere in Wisconsin lol Link to comment Share on other sites More sharing options...
spartan Posted January 17, 2011 Share Posted January 17, 2011 I had a pc680 on my galant vr4 for a few years of cold Michigan winters with no issues, and I had mine in the engine bay still. If I didn't have a stereo on my car now, I would think about getting another one. Link to comment Share on other sites More sharing options...
Th3Franz Posted January 18, 2011 Author Share Posted January 18, 2011 For now I am leaving it in the engine bay. I wrapped the battery in heat reflective tape and got a nice mount for it. It has more CCA and capacity than the OEM battery. And I heard about those V6 mustangs.. I'll really wish I had a Spec B now! I got a DEKA ETX-18L, so it least it's not a wimpy 10 lb battery -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
spec.B Dream Posted January 20, 2011 Share Posted January 20, 2011 Thanks for the update. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted January 23, 2011 Share Posted January 23, 2011 -Better weight distribution. -Heat is a battery killer. Getting the battery out of the engine bay will improve the longevity, even for sealed AGM batteries. Why do you want to spend extra money on a LW battery to put the weight back in the car with long wire? Are you corner-weight balancing your car? Could your engine bay get hot enough to damage a battery when the first one lasted six years? If you are concerned about heat why not wrap the turbo/dp/etc? EDIT: leaving it in the engine bay was a good call considering your goals. Link to comment Share on other sites More sharing options...
