whlightning Posted September 28, 2010 Share Posted September 28, 2010 2.2 engine, and can I hook up the turbo? any issues I may run into? also I have a lead on a 90 legacy engine the guy says its a 2.4, is that correct and would it work either? I have a 93 with a 2.2 with a spun bearing, debating on rebuild vs picking up a cheap motor and hooking up turbo and going. Thanks for the advise Bryan Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 5, 2010 I Donated Share Posted October 5, 2010 its almost always cheaper and easier to drop in a new motor rather then rebuilding. If I spin a rod or something simular - i just replace the engine. The 2.4L is non-existent. There has never been a Legacy with a 2.4L. There are 2.5L, but I don't think the first generation Legacys (up to 95) came with a 2.5. Every one that I have seen has been a 2.2L (if its USDM) As far as just transfering your turbo setup to a N/A EJ22, I don't know what kind of problems you would run into....I'm sure that there would have to be some custom work you would have to do on it. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Bassnectar Posted October 12, 2010 Share Posted October 12, 2010 if ej25d is stamped on the block i wouldn't turbo it Link to comment Share on other sites More sharing options...
