timbaru Posted September 22, 2010 Share Posted September 22, 2010 Just noticed a noise coming from my engine, looked under the hood and the crank pulley was wobbling. The nut was finger turnable so i tightened it back up until the crank started spinning, noise went away for a lil but came back because nut keeps coming loose. Is there a way to keep the shaft from turning while tightening the nut? Suggestions? Link to comment Share on other sites More sharing options...
subikid90 Posted September 22, 2010 Share Posted September 22, 2010 You need to hold the crank with a crank pulley tool and torque that bolt down. Dont drive till you fix this! -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
timbaru Posted September 23, 2010 Author Share Posted September 23, 2010 Ok so theres an actual tool that holds it? Link to comment Share on other sites More sharing options...
Project_Legacy Posted September 23, 2010 Share Posted September 23, 2010 Ive heard a few bad things about this when i used to own a first gen. Apparently if the crank pulley wasn't torqued properly, the keyway on the crank gets eaten up. Check that out too if you can. Link to comment Share on other sites More sharing options...
LuckyBob Posted September 23, 2010 Share Posted September 23, 2010 If it's a manual transmission you can also put it in the highest gear (not 1st) and torque against that. When I swapped my crank pulley on my Spec.B I just left it in 6th gear and was easily able to put 100+ft-lbs on it. Link to comment Share on other sites More sharing options...
