outahere Posted April 30, 2005 Share Posted April 30, 2005 Are there any specialty tools required to do routine maintenance and/or mods on the Legacy? I already have a T70 Torx bit ordered, for the transmission plug. Link to comment Share on other sites More sharing options...
Xenonk Posted April 30, 2005 Share Posted April 30, 2005 nope, not really.. well, it's good to have a set of box offset metric wrench set... other than that, a set of vice clamps for the brake calipers to push the pistons back in... Keefe Keefe Link to comment Share on other sites More sharing options...
Th3Franz Posted April 30, 2005 Share Posted April 30, 2005 If you install brake lines, make sure you have all the tools you need. haha I just figured that out tonight. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
03Indigo Posted April 30, 2005 Share Posted April 30, 2005 a set of vice clamps for the brake calipers to push the pistons back in... Keefe I found that interesting on our cars. On old subies, they needed the caliper tools to twist and compress the pistons, but now, looks like a normal compression both front and rear. Not that i mind, the caliper tools are sometimes a pain, but not that i have the universal kit, I am all bummed that I only get to use it on friends Audi's, VW's, and my MINI;) Nothing like a good vice clamp though, that and duct tape can fix all!!! Link to comment Share on other sites More sharing options...
zmarko Posted April 30, 2005 Share Posted April 30, 2005 If you install brake lines, make sure you have all the tools you need. haha I just figured that out tonight. Well that's helpful. What are "all the tools we'll need"? Link to comment Share on other sites More sharing options...
Opie Posted April 30, 2005 Share Posted April 30, 2005 Flare end wrenched come to mind... Link to comment Share on other sites More sharing options...
Xenonk Posted April 30, 2005 Share Posted April 30, 2005 ^+1.. it's for the 10mm flare nuts for the brake lines. a 4' iron pipe as your breaker bar does wonders. A plastic 3 lbs mallet or rubber hammer... yea, I call these MY SPECIAL tools. Keefe Keefe Link to comment Share on other sites More sharing options...
Th3Franz Posted May 1, 2005 Share Posted May 1, 2005 and 8mm really deep socket for the rear bleeder screws. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
