ExRex Posted April 29, 2005 Share Posted April 29, 2005 A few weeks back my right front endlink broke. I finally got it fixed under warranty and picked the car up last night. Is it me, or did I loose grip? The car feels like it pushes a lot more now and doesn't stick quite as well. Obviously it doesn't roll as much, which is nice. So what do you think, is what I am experiencing totally psychosymatic, or did I gain a flatter cornering attitude at the expense of ultimate adhesion? Link to comment Share on other sites More sharing options...
eamiller Posted April 29, 2005 Share Posted April 29, 2005 It's not your brain fooling you.. A stiffer rear will cause more oversteer. By having your front endlink break, the rear was significantly stiffer in roll resistance than the front causing more oversteering. However you do sacrifice extra body roll. Many autocrossers disconnect the front roll bar completely. Mostly on FWD cars though. Link to comment Share on other sites More sharing options...
Drift Monkey Posted April 29, 2005 Share Posted April 29, 2005 Perfect reason for you to get a larger rear bar now. Link to comment Share on other sites More sharing options...
Jaxx Posted April 30, 2005 Share Posted April 30, 2005 yup sway bars work by reducing grip Link to comment Share on other sites More sharing options...
