08LGT80 Posted September 10, 2010 Share Posted September 10, 2010 Hi guys, If I'm gonna install a spt intake.. will I run lean? Will I have knock? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 10, 2010 I Donated Share Posted September 10, 2010 No, you should be fine. Your ECU will compensate for the extra air that the engine is getting. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
E-Tank Posted September 10, 2010 Share Posted September 10, 2010 The SPT intake does not have a very good reputation. When changing any part of your exhaust or intake systems it is always wise to tune/have your car tuned. In fact, by throwing on an intake without a tune you're more likely to lose power. At the very least you should datalog after the install to ensure there's no lean condition or knock events. Every car is different. Link to comment Share on other sites More sharing options...
fonts Posted September 10, 2010 Share Posted September 10, 2010 Hi guys, If I'm gonna install a spt intake.. will I run lean? Will I have knock? Yes and yes..... unless you get it tuned. Save your money. Link to comment Share on other sites More sharing options...
08LGT80 Posted September 11, 2010 Author Share Posted September 11, 2010 The SPT intake does not have a very good reputation. When changing any part of your exhaust or intake systems it is always wise to tune/have your car tuned. In fact, by throwing on an intake without a tune you're more likely to lose power. At the very least you should datalog after the install to ensure there's no lean condition or knock events. Every car is different. lose power by increasing air flow? Link to comment Share on other sites More sharing options...
carbonsubie Posted September 12, 2010 Share Posted September 12, 2010 I have an intake and heat shield for sale if you decide to go this route. Link to comment Share on other sites More sharing options...
carbonsubie Posted September 12, 2010 Share Posted September 12, 2010 $150 shipped - chickened out and went with a K & N panel: http://legacygt.com/forums/showthread.php/fs-co-spt-intake-and-heat-shield-135730.html Link to comment Share on other sites More sharing options...
AZZMAN Posted September 12, 2010 Share Posted September 12, 2010 That's the intake I have for stg II. Do a tune your car will thank you. Link to comment Share on other sites More sharing options...
m sprank Posted September 12, 2010 Share Posted September 12, 2010 You will be rich, not lean. You should not knock. You will have zero power gain. Very erratic MAF readings make for a more difficult tune. Link to comment Share on other sites More sharing options...
