Urbanrunner Posted September 10, 2010 Share Posted September 10, 2010 Dear fellow subaru owners, I am currently considering a trunk lid swap, but had a few questions before doing so. I have swaped many trunk lids in the past on honda accords (my previous series of cars) but am currently unsure on how to swap the trunk lid from an 08 2.5iSE. Besides the bolts that hold on the trunk lid to the arms, how is the lock mechanism removed and are there any problems with trunk release? Any help would be much appreciated, maybe a walk through or even pics! SOrry if this was posted a while back, i could not find anything in searching. Thanks, Jason Link to comment Share on other sites More sharing options...
vr4Legacy Posted September 10, 2010 Share Posted September 10, 2010 Does your trunk have a key lock in it? My '08 GT doesn't, so unless you are getting a trunk without the entire mechanism, that shouldn't need to be touched, as the actual remote and lever release work from the base of the trunk lock. Link to comment Share on other sites More sharing options...
MDKSDMF Posted September 10, 2010 Share Posted September 10, 2010 so its just the bolts that connect the trunk? Link to comment Share on other sites More sharing options...
vr4Legacy Posted September 10, 2010 Share Posted September 10, 2010 I've looked at mine a couple times. If you don't have a spoiler looks like just bolts. If you have a spoiler there's obviously a wire too, but I think it connects right by the hinges..... but I've never done this before on a Suby..... I think the hardest thing would be realignment.... Link to comment Share on other sites More sharing options...
MDKSDMF Posted September 10, 2010 Share Posted September 10, 2010 i have a spoiler and plan on trading with another member in future for wingless trunk. looking for some good efficent advice as we will prob be doing the swap in a parking lot on neutral ground. Link to comment Share on other sites More sharing options...
slimjoe Posted September 10, 2010 Share Posted September 10, 2010 Other than the bolts holding the lid to the hinge arms, you also need to undo the power cable for the spoiler light and the cable for the trunk release. Both are pretty easy to do and you'll see them right away when you take the liner off. I found that the easiest way to realign the lid was to have someone in the trunk itself after you loosely rebolt it to the arms. Then you close the trunk, align it from the outside, then have the person inside bolt the thing down. Link to comment Share on other sites More sharing options...
legacychick Posted September 10, 2010 Share Posted September 10, 2010 Do you need someone to swap with? I'd like to get rid of my spoiler! Link to comment Share on other sites More sharing options...
MDKSDMF Posted September 10, 2010 Share Posted September 10, 2010 no thanks i got a member on here thats got a matching color spoilerless trunk for me. thanks for the tip SLIMJOE Link to comment Share on other sites More sharing options...
E-Tank Posted September 10, 2010 Share Posted September 10, 2010 Other than the bolts holding the lid to the hinge arms, you also need to undo the power cable for the spoiler light and the cable for the trunk release. Both are pretty easy to do and you'll see them right away when you take the liner off. I found that the easiest way to realign the lid was to have someone in the trunk itself after you loosely rebolt it to the arms. Then you close the trunk, align it from the outside, then have the person inside bolt the thing down. looks like when I do my trunk swap I'll finally get some use out of that half dead hooker. Link to comment Share on other sites More sharing options...
legacychick Posted September 10, 2010 Share Posted September 10, 2010 no thanks i got a member on here thats got a matching color spoilerless trunk for me. thanks for the tip SLIMJOE Sorry, I was talking to the OP. I thought maybe he didn't have anyone to trade with yet. Link to comment Share on other sites More sharing options...
jton Posted September 10, 2010 Share Posted September 10, 2010 Torredo and I did it. Took about 15 minutes. Its a whole bunch of pop pins. And 4 12 or 14mm bolts. Its all plug and play. Link to comment Share on other sites More sharing options...
MDKSDMF Posted September 15, 2010 Share Posted September 15, 2010 looks like when I do my trunk swap I'll finally get some use out of that half dead hooker. hahahahahahahahahahahahahahahaha Link to comment Share on other sites More sharing options...
BigBlack-V Posted September 15, 2010 Share Posted September 15, 2010 I just did mine a few weeks ago so read this thread and if you have any questions PM me and I will give you my phone number to explain it to you http://legacygt.com/forums/showthread.php/swap-trunki-92333.html?t=92333 I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
