Nvmylegacy Posted August 4, 2010 Share Posted August 4, 2010 so i just picked up a 2005 lgt with 27k on it. and i just realised that there is a small leak from one of the power steering lines that pass directly over the front passenger side axle. i checked my fluid level and im fine, and the leak is not that bad, its right where the line ends above the axle. and when i turn the wheel while not moving the steering wines. i called several dealers and they have no history of problems, can someone tell me if they had the same problem or why you think this happened? thanks Link to comment Share on other sites More sharing options...
