highwaydrifter Posted April 24, 2005 Share Posted April 24, 2005 And top mount? Was it shaggy who did that? just curious was there any clearence issues at all with the hood? Link to comment Share on other sites More sharing options...
ShaggyGT Posted April 25, 2005 Share Posted April 25, 2005 Yep it was me. And no clearance issues what so ever. -Matt Link to comment Share on other sites More sharing options...
highwaydrifter Posted April 26, 2005 Author Share Posted April 26, 2005 sweet cause i may be getting one soon and seeing if i can source myself a nice gt30 of some flavor or another... werent you going to do something similar? did you go with a stock sti top mount as well?? Link to comment Share on other sites More sharing options...
ShaggyGT Posted April 27, 2005 Share Posted April 27, 2005 Yes, I was in the process of installing a GT30R setup on mine. Though I am now considering installing it on my '91 Legacy Turbo sedan instead. The Legacy has been a real pain to modify and I dont like not being able to drive a brand new car. And yes I have and was going to use the STi TMIC, though mine is a Version 7 STi TMIC (Which is said to be larger and more efficent than the USDM TMIC). -Matt Link to comment Share on other sites More sharing options...
highwaydrifter Posted April 29, 2005 Author Share Posted April 29, 2005 the fuel pump is what is killing you huh? what issues have you run into that have stalled the project out? Link to comment Share on other sites More sharing options...
Enlight Posted April 29, 2005 Share Posted April 29, 2005 If I switch over to an STi intake manifold and TMIC would that allow proper fitment of popular STi aftermarket turbos? What should I look out for? Bessie II Link to comment Share on other sites More sharing options...
Drift Monkey Posted April 29, 2005 Share Posted April 29, 2005 I like my plastic intake manifold! Link to comment Share on other sites More sharing options...
chucktoo Posted April 29, 2005 Share Posted April 29, 2005 But how much pressure wil it hold ? We know the factory TMIC can be over presssureized and pop apart. Link to comment Share on other sites More sharing options...
Drift Monkey Posted April 29, 2005 Share Posted April 29, 2005 But how much pressure wil it hold ? We know the factory TMIC can be over presssureized and pop apart. True. It'll likey hold more pressure IMO. Link to comment Share on other sites More sharing options...
Xenonk Posted April 29, 2005 Share Posted April 29, 2005 yea, the problem with metal intercoolers with plastic manifolds.. you just can't weld them together Keefe Keefe Link to comment Share on other sites More sharing options...
Drift Monkey Posted April 29, 2005 Share Posted April 29, 2005 Welp, I guess it gives me more reason to get a bigger TMIC...or dare I say it? FMIC! Link to comment Share on other sites More sharing options...
ShaggyGT Posted April 29, 2005 Share Posted April 29, 2005 the fuel pump is what is killing you huh? what issues have you run into that have stalled the project out? Yep, fuel pump as well as waiting for PE to get the parts to me that were not included that should have been. Also the fact that the stock MAF doesnt like big turbos too much so the Intake will have to be resdesigned. I have mainly stopped due to shortage of funds for the project. -Matt Link to comment Share on other sites More sharing options...
highwaydrifter Posted April 30, 2005 Author Share Posted April 30, 2005 hmm the perrin big maf should take care of the maf issues shouldnt it? not sure on the voltage of the unit but i assume it would work.. PE?? power enterprise? waiting on injectors? I am thinking of starting to square away some parts to do a build maybe this coming winter... Link to comment Share on other sites More sharing options...
ShaggyGT Posted April 30, 2005 Share Posted April 30, 2005 Yes, PE stands for Power Enterprise. I wouldnt recommend anyone buy their crap parts. They will not stand behind their products and will not do what needs to be done to make a mistake on their part right. The Perrin MAF will not help me with my intake issue. The MAF needs to be further away from the turbo than what it currently is with the intake provided. If the MAF is too close then you will see issues at idle since the turbo will actually still be spinning, due to the fact that the GT30R is ball bearing. I am currently working on making a custom intake using an oversized TurboXS MAF housing. -Matt Link to comment Share on other sites More sharing options...
chucktoo Posted April 30, 2005 Share Posted April 30, 2005 PE 850 injecotrs have been used by many people including me with no problems. I expect you had a bad experiance ? A lot of that depends on who you bought them from - if Vivid they are very bad. PE is Japaneese so domestic support is not great. Even Perrin occasionally has problems with their injectors but they try very hard to take care of their customers. I have an extra set of new PE 850s in the boxes ,if you need them quickly PM me. Link to comment Share on other sites More sharing options...
ShaggyGT Posted May 1, 2005 Share Posted May 1, 2005 I got the PE injectors from one of PE's main US distributors. I got the injectors and one of them were missing the aluminum adapter ring and the rubber o-rings. Without those items the injectors can not be installed properly. I know how buisness works. I have a shop of my own and I know about customer service and how important it is to have good customer service in order to have a good buisness. I say I wouldnt recommend anyone else buy PE injectors, because there are much better options out there from companys who offer much better customer service. I have been around Subaru's for a LONG time, so I definitely know about Vivid. Thanks. -Matt Link to comment Share on other sites More sharing options...
highwaydrifter Posted May 1, 2005 Author Share Posted May 1, 2005 maybe someone should give RC a call and see if they can start fabbing up some injectors? I have had nothing but awesome luck with my rc's Link to comment Share on other sites More sharing options...
firedawgs Posted May 1, 2005 Share Posted May 1, 2005 Whats the price of the STi intake manifold?? Is it a direct fit to our without modifications? Updated my vBGarage: Link to comment Share on other sites More sharing options...
ShaggyGT Posted May 1, 2005 Share Posted May 1, 2005 Whats the price of the STi intake manifold?? Is it a direct fit to our without modifications? SEARCH Link to comment Share on other sites More sharing options...
firedawgs Posted May 1, 2005 Share Posted May 1, 2005 Come on now.... Do I really have to search?? Updated my vBGarage: Link to comment Share on other sites More sharing options...
ShaggyGT Posted May 2, 2005 Share Posted May 2, 2005 Considering I have covered it atleast 5 times..... YES. In a nut shell, NO it isnt a BOLT ON. Requires a turbo and intercooler swap. And if you get any STi Intake other than the USDM STi one then you will need an adapter to make it work. -Matt Link to comment Share on other sites More sharing options...
highwaydrifter Posted May 2, 2005 Author Share Posted May 2, 2005 mine is going to cost me nothing teehee hee Link to comment Share on other sites More sharing options...
firedawgs Posted May 2, 2005 Share Posted May 2, 2005 Come on now.... Do I really have to search?? Ok, I did the search anyway. Sorry that you had to repeat yourself, won't happen again. Updated my vBGarage: Link to comment Share on other sites More sharing options...
John M Posted May 2, 2005 Share Posted May 2, 2005 I'm surprised to hear that RC doesn't have injectors for our cars. What's so different? Link to comment Share on other sites More sharing options...
rao Posted May 2, 2005 Share Posted May 2, 2005 I don't know why you would use anything other than the Perrin modified stock injectors; they have the same characteristics as the stock injetors,with a lot more flow. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
